Long Range Night Vision Doorbell with Dual Sensors for Better Depth Perception: Wyze Duo Cam Doorbell
When it comes to securing your home with crystal-clear video and advanced sensing technology, the
Wyze Duo Cam Doorbell stands out as the ultimate choice. Designed with dual sensors for enhanced depth perception and long-range night vision, this doorbell offers unparalleled security and convenience.
Wyze Duo Cam Doorbell: Dual Sensors for Superior Depth Perception
Dual Camera Views for Complete Coverage
The Wyze Duo Cam Doorbell features two cameras in one device, providing two distinct views:
- Front Camera: Captures 2K resolution video (2048 x 1536) with a wide 132° horizontal and 100° vertical field of view.
- Bottom Camera: Focuses on packages and ground-level activity with 1080p resolution and a 121° horizontal by 60° vertical field of view.
This dual-camera setup ensures you never miss a detail, whether it’s a visitor at your door or a package left on your porch.
Long Range Night Vision with 6x 850 nm IR Lights
Equipped with six infrared lights, the Wyze Duo Cam Doorbell delivers clear night vision up to a long range, allowing you to see visitors and objects even in complete darkness. The 850 nm IR lights provide a stealthy, non-glowing illumination that won’t alert intruders.
Advanced Motion Detection and AI Alerts
With real-time AI detections, the doorbell intelligently distinguishes between people, packages, and other motion events. This reduces false alerts and ensures you get notified only when it matters.
Two-Way Audio and Voice Deterrence
Communicate directly with visitors or deter unwanted guests using the built-in two-way talk feature and motion-activated voice deterrence. The doorbell also includes a siren with 90 dB output for added security.
Flexible Power Options and Local Storage
- Battery-powered with a removable 6200 mAh lithium-ion battery pack for easy charging via USB-C.
- Can also be hardwired with 10-24V AC power.
- Supports local microSD storage up to 256 GB (sold separately) for continuous recording.
- Cloud storage available via Wyze Security Plan.
Weather Resistant and Durable
Rated IP65 for weather resistance, the Wyze Duo Cam Doorbell is built to withstand harsh outdoor conditions, operating reliably between -4°F to 122°F (-20°C to 50°C).
"Wyze Duo Cam Doorbell combines dual sensors and long-range night vision to provide unmatched home security and peace of mind."
Wyze Duo Cam Doorbell installed on a modern home exterior, showcasing its sleek design and smart security features.
Wyze Video Doorbell v2: Wired 2K Video with Starlight Sensor
Crisp 2K Video Resolution and Wide Field of View
The Wyze Video Doorbell v2 offers 2K (2048 x 1536) video resolution with a wide 166.8° diagonal field of view, ensuring you capture every detail at your doorstep.
CMOS Starlight Sensor for Enhanced Night Vision
Featuring a CMOS Starlight Sensor and six 940 nm IR lights, this wired doorbell excels in low-light conditions, providing clear black-and-white night vision with excellent depth perception.
Essential Doorbell Features
- Two-way audio with ECM microphone and 8Ω 1W speaker.
- Motion-activated voice deterrence to warn off unwanted visitors.
- Real-time alerts sent directly to your phone.
- Local microSD storage support up to 256 GB for continuous recording.
Durable and Weather Resistant
Constructed with polycarbonate body and resin lens, the doorbell is IP65 certified for weather resistance, suitable for outdoor use in temperatures ranging from -4°F to 122°F (-20°C to 50°C).
Easy Installation and Integration
Compatible with Alexa, Google Assistant, and IFTTT, the Wyze Video Doorbell v2 integrates seamlessly into your smart home ecosystem.
Wyze Video Doorbell v2 mounted on a front porch, highlighting its sleek design and smart home compatibility.
Wyze Duo Cam Pan: Dual 2K Cameras with Pan & Tilt for Versatile Coverage
Two 2K Cameras in One Device
The Wyze Duo Cam Pan combines two 2K cameras:
- One fixed camera for your priority view.
- One pan-and-tilt camera with 360° horizontal and 180° vertical movement to track motion automatically.
Enhanced Color Night Vision and Spotlights
Unlike traditional IR night vision, this camera offers color night vision with integrated spotlights, providing vivid images even in low light.
Smart Features for Complete Security
- Auto motion tracking and customizable detection zones.
- Integrated siren and enhanced two-way talk.
- Supports continuous local recording with microSD cards up to 512 GB.
- Works with Alexa, Google Assistant, and IFTTT.
Weatherproof and Durable
IP65 rated for outdoor use, the Duo Cam Pan withstands harsh weather and operates reliably in temperatures from -4°F to 122°F (-20°C to 50°C).
"Wyze Duo Cam Pan offers dynamic coverage with dual cameras and pan-tilt functionality, perfect for monitoring large outdoor areas."
Why Choose Wyze for Your Night Vision Doorbell Needs?
Wyze offers a range of video doorbells and cameras that combine high-resolution video, advanced sensor technology, and smart home integration at an affordable price. Whether you prefer a wired solution like the Wyze Video Doorbell v2 or the versatile battery-powered Wyze Duo Cam Doorbell with dual sensors, Wyze ensures you get superior night vision, depth perception, and reliable security features.
Summary of Featured Products
Product Name | Key Features | Price (USD) |
Wyze Duo Cam Doorbell | Dual 2K cameras, long-range IR night vision, AI alerts, battery or wired power | From $89.98 |
Wyze Video Doorbell v2 | Wired 2K video, starlight sensor, local storage, IP65 weather resistance | $44.98 |
Wyze Duo Cam Pan | Dual 2K cameras, pan & tilt, color night vision, spotlights, siren | From $69.98 |
What is the Wyze Duo Cam Doorbell and how does it enhance home security?
The Wyze Duo Cam Doorbell is a smart video doorbell featuring dual cameras and advanced sensors for superior depth perception and security. It offers 2K resolution video, long-range night vision with 6x 850 nm IR lights, real-time AI motion detection, two-way audio, and flexible power options. Its dual-camera setup ensures you never miss a visitor or package, providing comprehensive coverage for your front door.How does the dual camera system work on the Wyze Duo Cam Doorbell?
The Wyze Duo Cam Doorbell features two cameras: a front camera with 2K resolution and a wide 132° horizontal by 100° vertical field of view, and a bottom camera with 1080p resolution and a 121° horizontal by 60° vertical field of view. This dual-camera system allows you to monitor both visitors at eye level and packages or activity at ground level, ensuring complete coverage.Does the Wyze Duo Cam Doorbell have night vision?
Yes, the Wyze Duo Cam Doorbell is equipped with six 850 nm infrared lights, providing long-range night vision. This allows you to see visitors and objects clearly even in complete darkness, enhancing your home security at night.What motion detection and alert features does the Wyze Duo Cam Doorbell offer?
The Wyze Duo Cam Doorbell uses advanced AI-powered motion detection to distinguish between people, packages, and other motion events. This reduces false alerts and ensures you receive notifications only when important activity is detected at your door.Can I communicate with visitors using the Wyze Duo Cam Doorbell?
Yes, the Wyze Duo Cam Doorbell includes two-way audio, allowing you to speak directly with visitors. It also features motion-activated voice deterrence and a 90 dB siren to help deter unwanted guests.What are the power and storage options for the Wyze Duo Cam Doorbell?
The Wyze Duo Cam Doorbell can be powered by a removable 6200 mAh lithium-ion battery pack or hardwired with 10-24V AC power. For storage, it supports local microSD cards up to 256 GB (sold separately) for continuous recording, and cloud storage is available via the Wyze Security Plan.Is the Wyze Duo Cam Doorbell weather resistant?
Yes, the Wyze Duo Cam Doorbell is rated IP65 for weather resistance, making it suitable for outdoor use in temperatures ranging from -4°F to 122°F (-20°C to 50°C).What are the key features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers 2K video resolution, a wide 166.8° diagonal field of view, a CMOS Starlight Sensor for enhanced night vision, two-way audio, motion-activated voice deterrence, real-time alerts, and local microSD storage up to 256 GB. It is wired, weather resistant (IP65), and integrates with Alexa, Google Assistant, and IFTTT.How does the Wyze Duo Cam Pan differ from the other Wyze doorbells?
The Wyze Duo Cam Pan features two 2K cameras: one fixed and one with pan-and-tilt capability for 360° horizontal and 180° vertical movement. It offers color night vision with integrated spotlights, auto motion tracking, customizable detection zones, an integrated siren, and supports local microSD storage up to 512 GB. It is also IP65 weatherproof and compatible with Alexa, Google Assistant, and IFTTT.Are Wyze doorbells compatible with smart home systems?
Yes, Wyze doorbells such as the Wyze Video Doorbell v2 and Wyze Duo Cam Pan are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.Why should I choose Wyze for my night vision doorbell needs?
Wyze offers a range of video doorbells and cameras that combine high-resolution video, advanced sensor technology, superior night vision, and smart home integration at an affordable price. Whether you need a wired or battery-powered solution, Wyze ensures reliable security, enhanced depth perception, and peace of mind for your home.
