Effortlessly Connect Your Wyze Cam v4 to Alexa for Seamless Voice Control and Viewing
The Wyze Cam v4 is an excellent choice for those looking to integrate their security system with Alexa for voice commands and viewing. This camera offers crystal-clear 2.5K QHD resolution and Enhanced Color Night Vision, ensuring you have a clear view of your surroundings day or night. It also supports Wi-Fi 6, providing a fast and reliable connection. With compatibility with Alexa and Google Assistant, you can easily control and view your Wyze Cam v4 using voice commands, making it a convenient addition to your smart home setup.
Wyze Cam v4: 2.5K QHD resolution, Enhanced Color Night Vision, Alexa and Google Assistant compatibility, Wi-Fi 6 support.
Feature | Wyze Cam v4 Home Security Bundle | Wyze Cam v4 |
Resolution | 2.5K QHD | 2.5K QHD |
Color Night Vision | Enhanced | Enhanced |
Alexa & Google Assistant Support | Yes | Yes |
Wi-Fi Support | Wi-Fi 6 | Wi-Fi 6 |
Local Recording | 24/7 with microSD card | 24/7 with microSD card |
Motion-Activated Spotlight | Yes | Yes |
Person Detection | With Cam Plus | With Cam Plus |
Indoor/Outdoor Use | Yes, IP65 rated | Yes, IP65 rated |
Bundle Contents | 4x Wyze Cam v4, 4x MicroSD Card | Not applicable |
Price | $169.99 | Starting at $35.98 |
Stock Availability | Available | Available |
What features does the Wyze Cam v4 offer for home security?Can the Wyze Cam v4 be used with Google Assistant as well?What is the resolution of the Wyze Cam v4?
