Like New Refurbished Wyze Robot Vacuum with 7 Sensor Groups
Discover the power of smart cleaning with the Wyze Robot Vacuum, now available refurbished and equipped with advanced 7 sensor groups for superior navigation and cleaning efficiency. While the Wyze Robot Vacuum itself is not listed here, Wyze offers a comprehensive ecosystem of connected home devices that perfectly complement your smart cleaning experience.
Enhance your home automation and security with Wyze’s range of smart devices designed to work seamlessly together, including smart switches, cameras, and security bundles.
Wyze Switch: Smart Control for Your Wyze Robot Vacuum and More
Transform Your Home Lighting and Device Control
The Wyze Switch is a smart WiFi light switch that turns your regular lights into smart lights, controllable from anywhere via the Wyze app. It’s designed to integrate effortlessly with other Wyze devices, including the Wyze Robot Vacuum.
- Multi-tap Control: Use single, double, or triple taps to control lights, lock doors, or even start your Wyze Robot Vacuum.
- Smart Bulb Compatibility: Keeps power flowing to Wyze Bulbs to maintain automations without interruption.
- Custom Actions: Personalize actions such as single-press to turn on lights, double-press to lock doors, and triple-press to activate the robot vacuum.
- Power Loss Recovery: Automatically reconnects to Wi-Fi and resumes previous state after power outages.
- Vacation Mode: Simulate occupancy by scheduling lights to turn on/off when you’re away.
This switch is an essential companion for your Wyze Robot Vacuum, enabling you to start cleaning with a simple tap or automate it as part of your smart home routine.
Alt text: Modern kitchen with Wyze Switch controlling smart lights and devices
Enhance Your Home Security While Your Robot Vacuum Cleans
Essential Security Bundle: Comprehensive Home Protection
While your Wyze Robot Vacuum keeps your floors spotless, the Essential Security Bundle ensures your home stays safe from every angle. This all-in-one package includes:
- Wyze Video Doorbell v2: Crisp 1080p HD video with two-way audio to monitor your front door.
- Wyze Lock Bolt: Smart lock with fast fingerprint sensor and backlit keypad for secure, keyless entry.
- Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, motion tracking, and color night vision.
- Two Wyze Cam OG Cameras: Versatile indoor/outdoor cameras with motion-activated spotlights and color night vision.
This bundle complements your smart home ecosystem, allowing you to monitor and secure your home remotely while your robot vacuum handles cleaning.
Smart Lighting and Camera Bundles to Complete Your Setup
Cam v4 + Lamp Socket v2 Bundle: Smarter Outdoor Lighting
Power your Wyze Cam v4 without an outlet using the Lamp Socket v2, which also features motion-activated lights and dusk-to-dawn scheduling. This bundle is perfect for enhancing outdoor security and lighting, working in harmony with your indoor Wyze Robot Vacuum for a fully automated home.
- Convenient Power: Powers Wyze Cam v4 directly from a lamp socket.
- Motion-Activated Lights: Automatically lights up your outdoor space when motion is detected.
- Linkability: Connects seamlessly with other Wyze devices.
- Weather-Resistant: Suitable for damp locations.
Whole Home Security Starter Kit
This kit includes a Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit, providing a robust security foundation. The Wyze Cam v4 offers crystal-clear video and smart detection features, ideal for keeping an eye on your home while your robot vacuum cleans.
Wyze Cam v4 Outdoor Bundle
For enhanced outdoor security, the Wyze Cam v4 Outdoor Bundle offers:
- 2.5K QHD Resolution: Crystal-clear video quality.
- Enhanced Color Night Vision: See more detail in low light.
- Motion-Activated Spotlight: Deters unwanted visitors.
- Wi-Fi 6 Support: Faster, more reliable connectivity.
- Compatibility: Works with Alexa and Google Assistant.
Alt text: Outdoor home security camera mounted on house exterior
Why Choose Wyze for Your Smart Home?
Wyze offers a full ecosystem of smart home products that work together to simplify your life. From smart switches that control your robot vacuum and lights, to advanced security cameras and locks, Wyze provides affordable, reliable, and easy-to-use devices.
"Wyze devices bring smart home convenience and security to your fingertips, making everyday tasks effortless and your home safer."
Summary of Featured Products
- Wyze Switch: Smart light switch with multi-tap control and automation for Wyze devices including robot vacuum.
- Essential Security Bundle: Complete home security with video doorbell, smart lock, pan-tilt camera, and indoor/outdoor cams.
- Cam v4 + Lamp Socket v2 Bundle: Powers Wyze Cam v4 with motion-activated lighting for smarter outdoor security.
- Whole Home Security Starter Kit: Includes Wyze Cam v4, video doorbell, and home monitoring kit for comprehensive protection.
- Wyze Cam v4 Outdoor Bundle: High-resolution outdoor camera with spotlight and night vision for 24/7 security.
What is the Wyze Robot Vacuum and how does it work?
The Wyze Robot Vacuum is a smart cleaning device equipped with advanced 7 sensor groups for superior navigation and cleaning efficiency. It can be integrated into your Wyze smart home ecosystem, allowing for automated and remote-controlled cleaning through the Wyze app or compatible Wyze devices.What features does the Wyze Switch offer for smart home automation?
The Wyze Switch is a smart WiFi light switch that allows you to control your lights and other Wyze devices, such as the Wyze Robot Vacuum, from anywhere using the Wyze app. It supports multi-tap control, custom actions, power loss recovery, and vacation mode for enhanced convenience and automation.How can I control my Wyze Robot Vacuum using the Wyze Switch?
You can start your Wyze Robot Vacuum with a simple tap on the Wyze Switch. The switch supports customizable actions, such as single-press to turn on lights, double-press to lock doors, and triple-press to activate the robot vacuum, making it easy to integrate cleaning into your smart home routines.What is included in the Wyze Essential Security Bundle?
The Wyze Essential Security Bundle includes a Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This comprehensive package provides video monitoring, smart locking, and indoor/outdoor surveillance to keep your home secure while your robot vacuum cleans.How does the Cam v4 + Lamp Socket v2 Bundle enhance outdoor security?
The Cam v4 + Lamp Socket v2 Bundle powers your Wyze Cam v4 directly from a lamp socket and features motion-activated lighting and dusk-to-dawn scheduling. It is weather-resistant and integrates seamlessly with other Wyze devices for smarter outdoor security and lighting.What products are included in the Wyze Whole Home Security Starter Kit?
The Wyze Whole Home Security Starter Kit includes a Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit. This kit provides a robust foundation for home security, offering video monitoring and smart detection features.What are the key features of the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant. It is designed for high-quality, reliable outdoor security.Why should I choose Wyze for my smart home devices?
Wyze offers a comprehensive ecosystem of affordable, reliable, and easy-to-use smart home products. Their devices, including smart switches, cameras, locks, and robot vacuums, work seamlessly together to simplify your life and enhance your home’s security and automation.Can Wyze devices be controlled remotely?
Yes, Wyze devices can be controlled remotely through the Wyze app, allowing you to manage your lights, security cameras, robot vacuum, and more from anywhere.Are Wyze smart home products compatible with voice assistants?
Many Wyze smart home products, such as the Wyze Cam v4 Outdoor Bundle, are compatible with popular voice assistants like Alexa and Google Assistant, enabling hands-free control and integration into your smart home ecosystem.
