Discreet Home Security: Wyze Window Mount for Hidden Camera Setup Behind Curtains and Glass
For those looking to maintain a discreet security setup, the Wyze Window Mount is an ideal solution. This accessory allows you to mount your Wyze Cam v3, v3 Pro, v4, Cam OG, or Cam OG Telephoto directly onto a glass surface, ensuring a clear view free of glare or reflection. This makes it perfect for placing your camera behind a curtain or glass, keeping it out of sight while still capturing high-quality footage. Additionally, the Wyze Cam v4 is a top choice for enhancing your security measures. It offers:
  • Crystal-clear 2.5K QHD resolution: Ensures every detail is captured with clarity.
  • Enhanced Color Night Vision: Provides vibrant color images even in low-light conditions.
  • Motion-activated spotlight: Adds an extra layer of security by illuminating the area when motion is detected.
  • 24/7 local recording: Allows continuous monitoring without missing a moment.
  • Compatibility with Alexa and Google Assistant: Offers seamless integration with your smart home setup.
Together, these products provide a discreet yet powerful security solution for your home, ensuring peace of mind without compromising on aesthetics.
FeatureWyze Window MountWyze Cam v4
Product TypeAccessoryCamera
CompatibilityWyze Cam v3, v3 Pro, v4, Cam OG, Cam OG TelephotoCompatible with Alexa and Google Assistant
PurposeMounts camera on glass surface, reduces glare and reflectionProvides security with 2.5K QHD resolution and enhanced color night vision
Price$4.99 (v2 style)$35.98 (1 Pack)
Stock AvailabilityAvailable (v2 style)Available
Night VisionN/AEnhanced Color Night Vision
Motion DetectionN/AYes, with motion-activated spotlight
Local RecordingN/A24/7 local recording
Weather ResistanceN/AIP65 weather resistant
MountingGlass surfaceStand, wall mount, ceiling mount, magnetic wall mount
Additional FeaturesN/AWi-Fi 6 support, Smart Focus, 2-way audio
Can the Wyze Window Mount be used with other camera models besides the ones mentioned?What are the installation steps for the Wyze Window Mount?What is the warranty policy for the Wyze Window Mount?
