If you're looking for an inexpensive doorbell camera with two-way talk, we have some great options for you:
Wyze Video Doorbell v2
- Offers 2K video resolution for clear and detailed footage.
- Features two-way audio, allowing you to communicate with visitors at your door.
- Includes local microSD storage, so you can capture every moment without a subscription.
- Provides real-time alerts and motion-activated voice deterrence.
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
Wyze Duo Cam Doorbell
- Equipped with dual camera views for enhanced coverage of people and packages.
- Provides 2K video resolution and color night vision for clear images, even in low light.
- Includes two-way audio for easy communication with visitors.
- Comes with a Wyze Wi-Fi Chime for notifications throughout your home.
- Can be powered by a removable battery pack or hardwired for continuous power.
Wyze Video Doorbell Pro
- Features a wider view and higher resolution with 1440x1440p Full HD video.
- Offers two-way audio for direct communication with visitors.
- Can be installed in just 30 seconds, either wired or wirelessly with battery power.
- Compatible with both 2.4 GHz and 5 GHz Wi-Fi networks for flexible connectivity.
These options provide excellent features at an affordable price, ensuring you can keep an eye on your front door with ease.
