Wyze Cam Pan v3: Flexible Indoor Security Camera for Shelves & Mounts
Indoor Security Camera with Flexible Placement: Wyze Cam Pan v3
When it comes to indoor security cameras that offer versatile placement options—whether on shelves or mounted—the Wyze Cam Pan v3 stands out as a top choice. This camera is designed to fit seamlessly into your home environment, providing 360° pan and 180° tilt coverage, making it perfect for monitoring every corner of a room from a single spot.
Wyze Cam Pan v3: Features & Benefits
360° Pan and 180° Tilt for Full Room Coverage
The Wyze Cam Pan v3 offers a complete panoramic view with its 360-degree horizontal pan and an impressive 180-degree vertical tilt. This means it can look straight up and down, covering areas that many other cameras miss. Whether placed on a shelf or mounted on a wall, it can scan the entire room effortlessly.
Flexible Placement: Shelf or Mount
Thanks to its compact design and standard 1/4”–20 screw hole, the Wyze Cam Pan v3 can be easily mounted on walls, ceilings, or simply placed on shelves. This flexibility allows you to position the camera exactly where you need it without compromising on coverage or aesthetics.
Weather-Resistant for Indoor and Outdoor Use
Though perfect for indoor use, the Pan v3 is also IP65 rated, making it weather-resistant and suitable for outdoor environments when paired with the Wyze Outdoor Power Adapter (sold separately). This durability means you can confidently place it in areas exposed to rain or snow without worry.
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1_7d89a30d-1292-41d4-b3ef-71d305710824.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3: Weather-resistant and versatile for indoor/outdoor use
Automatic Motion Tracking
The camera automatically detects motion, follows the moving object, and records it. Its upgraded tracking motor operates quietly, ensuring it won’t disturb sleeping babies or pets while keeping your home secure.
Privacy Mode for Peace of Mind
When you want privacy, simply activate Privacy Mode via the Wyze app. The camera will rotate 180° downward, turning off its field of view and camera functions, so you can relax without feeling watched.
Two-Way Audio for Real-Time Communication
Wyze Cam Pan v3 features built-in two-way audio, allowing you to listen and speak through the camera using the Wyze app. This is perfect for interacting with family members, pets, or even deterring unwanted visitors.
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Two-way audio feature with pet">
Communicate easily with two-way audio
Color Night Vision with Starlight Sensor
Unlike traditional black-and-white night vision, the Pan v3 provides full-color night vision, capturing every detail clearly even in low-light conditions.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For those looking to enhance their security experience, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same great camera with an added 30-day free trial of Cam Plus. This subscription service unlocks unlimited event video cloud storage and advanced notifications such as person, package, and vehicle detection.
Benefits of the Bundle
  • Unlimited cloud storage for recorded events
  • Advanced AI-powered alerts (crying baby, barking pet, etc.)
  • Custom detection zones to focus on important areas
  • Smoke and carbon monoxide alarm alerts sent directly to your phone
This bundle is ideal for users who want comprehensive monitoring with smart notifications and extended video history.
Optional Accessories for Enhanced Placement and Power
Pan v3 + Lamp Socket v2 Bundle
If you want to power your Wyze Cam Pan v3 without relying on a traditional outlet, the Lamp Socket v2 lets you plug the camera into any standard E26 lamp socket. This accessory is perfect for flexible placement in rooms where outlets are limited.
  • Compatible with Wyze Cam Pan v3 and other Wyze Cam models
  • Supports CFL or LED bulbs under 20W (incandescent bulbs not recommended)
  • Easy installation and ideal for damp locations (not fully weatherproof)
Why Choose Wyze Cam Pan v3 for Indoor Security?
  • Flexible mounting options: shelf, wall, ceiling, or lamp socket
  • Comprehensive coverage: 360° pan and 180° tilt
  • Weather-resistant: suitable for indoor and outdoor use
  • Smart features: motion tracking, two-way audio, privacy mode
  • Affordable pricing: high-end features at a budget-friendly price
Whether you want to keep an eye on your pets, monitor your baby’s room, or secure your home with a camera that fits perfectly on shelves or mounts, the Wyze Cam Pan v3 is a versatile and reliable choice.
Technical Specifications at a Glance
FeatureSpecification
Pan Range360° horizontal
Tilt Range180° vertical
Resolution1080p Full HD
Night VisionColor night vision with Starlight sensor
AudioTwo-way audio
Weather ResistanceIP65 rated (outdoor use with adapter)
Connectivity2.4 GHz Wi-Fi
PowerUSB powered (adapter included)
Mounting1/4”–20 screw hole for mounts
Wyze Cam Pan v3 combines flexibility, smart features, and durability, making it the perfect indoor security camera that fits on shelves or mounts for flexible placement.
FeatureWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
Price$39.98$39.98
Includes Cam Plus SubscriptionNoYes, 30 days free trial
Subscription Auto-RenewalN/A$2.99/month/cam after first month, auto-renews
Camera TypeIndoor/Outdoor, 360° pan, 180° tiltIndoor/Outdoor, 360° pan, 180° tilt
Weather ResistanceIP65IP65
Outdoor Power Adapter RequiredYes (sold separately)Yes (sold separately)
Motion TrackingYesYes
Privacy ModeYesYes
Two-Way AudioYesYes
Color Night VisionYes (Starlight Sensor)Yes (Starlight Sensor)
Video Resolution1080p1080p
Pan & Tilt Range360° pan, 180° tilt360° pan, 180° tilt
Motion & Sound DetectionYesYes
Custom Detection ZonesYesYes
Smoke & CO Alarm AlertsYesYes
Local Storage SupportmicroSD card (sold separately)microSD card (sold separately)
Cloud Storage14-day free cloud storage14-day free cloud storage + Cam Plus advanced
CompatibilityAndroid 7.0+, iOS 12.0+Android 7.0+, iOS 12.0+
Warranty1 Year1 Year
What is the Wyze Cam Pan v3 and what makes it unique for indoor security?The Wyze Cam Pan v3 is a versatile indoor security camera designed for flexible placement on shelves or mounts. It features 360° pan and 180° tilt, allowing full room coverage from a single spot. Its compact design and advanced features make it ideal for monitoring every corner of your home.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is IP65 weather-resistant and can be used outdoors when paired with the Wyze Outdoor Power Adapter (sold separately). This makes it suitable for both indoor and outdoor environments, even in rain or snow.
How does the Wyze Cam Pan v3 provide full room coverage?The Wyze Cam Pan v3 offers a 360-degree horizontal pan and a 180-degree vertical tilt, enabling it to scan and monitor every corner of a room. This ensures comprehensive coverage whether the camera is placed on a shelf or mounted on a wall or ceiling.
What mounting options are available for the Wyze Cam Pan v3?The Wyze Cam Pan v3 can be placed on shelves, mounted on walls or ceilings using its standard 1/4”–20 screw hole, or powered via a lamp socket with the optional Lamp Socket v2 accessory. This flexibility allows you to position the camera wherever you need it.
Does the Wyze Cam Pan v3 have motion tracking?Yes, the Wyze Cam Pan v3 features automatic motion tracking. It detects motion, follows the moving object, and records the activity. The upgraded tracking motor operates quietly, making it suitable for monitoring babies or pets without disturbance.
What is Privacy Mode on the Wyze Cam Pan v3?Privacy Mode allows you to temporarily disable the camera’s field of view and functions. When activated via the Wyze app, the camera rotates 180° downward and stops recording, giving you peace of mind when privacy is needed.
Does the Wyze Cam Pan v3 support two-way audio?Yes, the Wyze Cam Pan v3 includes built-in two-way audio. You can listen and speak through the camera using the Wyze app, making it easy to communicate with family members, pets, or deter unwanted visitors in real time.
Does the Wyze Cam Pan v3 have color night vision?Yes, the Wyze Cam Pan v3 is equipped with a Starlight sensor that provides full-color night vision. This allows the camera to capture clear, detailed footage even in low-light conditions, unlike traditional black-and-white night vision cameras.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera and a 30-day free trial of Cam Plus. Cam Plus offers unlimited event video cloud storage, advanced AI-powered notifications (such as person, package, and vehicle detection), custom detection zones, and smoke or carbon monoxide alarm alerts sent directly to your phone.
What are the benefits of the Lamp Socket v2 accessory for Wyze Cam Pan v3?The Lamp Socket v2 allows you to power the Wyze Cam Pan v3 using any standard E26 lamp socket, making it ideal for rooms with limited outlets. It supports CFL or LED bulbs under 20W and is easy to install, though it is not fully weatherproof.
What are the technical specifications of the Wyze Cam Pan v3?The Wyze Cam Pan v3 features a 360° horizontal pan, 180° vertical tilt, 1080p Full HD resolution, color night vision with a Starlight sensor, two-way audio, IP65 weather resistance (with outdoor adapter), 2.4 GHz Wi-Fi connectivity, USB power (adapter included), and a 1/4”–20 screw hole for mounting.
Why should I choose the Wyze Cam Pan v3 for indoor security?The Wyze Cam Pan v3 offers flexible mounting options, comprehensive 360° pan and 180° tilt coverage, weather resistance for indoor and outdoor use, smart features like motion tracking and two-way audio, privacy mode, and affordable pricing. It is a reliable and versatile choice for home security.
What are the specific features of the Wyze Cam Pan v3 that make it suitable for indoor use?Can the Wyze Cam Pan v3 be used outdoors, and what do I need to consider for that?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Pan v3?
