Enhance Audio Clarity for Wyze Cam with Window Mount: Tips for Optimal Security Setup
Enhance your security setup with the Wyze Window Mount. This accessory allows you to attach your Wyze Cam v3, v3 Pro, v4, Cam OG, or Cam OG Telephoto directly to a window, providing a clear view without glare or reflection. For those experiencing audio clarity issues when the camera is mounted behind a pane, ensure that the camera's microphone is not obstructed and that the audio settings are correctly configured in the Wyze app. Additionally, make sure your Wyze app and camera firmware are up to date to benefit from the latest improvements and features.
What should I do if the microphone of my Wyze Cam is obstructed?How can I check if my Wyze app and camera firmware are up to date?Are there any specific audio settings I should configure in the Wyze app for better clarity?
