Maximize Playback Time with a 128GB Wyze microSDHC Card: Tips for Continuous and Event-Only Recording
To achieve longer playback with a 128GB Wyze microSDHC card, you can utilize the continuous recording feature on your Wyze Battery Cam Pro. This allows your camera to record video continuously to the microSD card, providing you with extended playback options. However, please note that continuous recording will significantly drain the battery, so we recommend connecting your camera to a 5V 2A AC power source for optimal performance. The Wyze Battery Cam Pro supports microSD cards up to 256GB in exFAT format, which can hold approximately 2-3 days of playback recording. If you prefer to conserve battery life, consider using the "Events Only" recording mode, which records only when motion is detected.
What are the benefits of using the continuous recording feature on the Wyze Battery Cam Pro?How does the "Events Only" recording mode work on the Wyze Battery Cam Pro?Can I use a microSD card larger than 128GB with the Wyze Battery Cam Pro?
