How to Add 24/7 Local Storage to Wyze Cam with MicroSD Card
How to Add Local Storage to Your Wyze Cam for 24/7 Footage Using Wyze MicroSD Card
If you're looking to enable continuous 24/7 recording on your Wyze Cam, adding local storage with a Wyze MicroSD Card is the perfect solution. This guide will walk you through the benefits, compatible products, and step-by-step instructions to set up local storage for uninterrupted video footage.
Wyze MicroSD Card: Unlock Continuous Local Recording
Overview
The Wyze MicroSD Card is specially designed to unlock continuous recording and time lapse features for Wyze Cams. Available in multiple sizes—32GB, 128GB, and 256GB—this memory card allows you to store video footage locally without relying solely on cloud storage.
Key Features
  • Local Recording: Save videos directly to the microSD card for offline access.
  • Timeline Controls & Calendar View: Easily scroll through recorded footage by date and time.
  • Continuous Recording: Capture 24/7 footage without missing a moment.
  • Time Lapse: Create time lapse videos for quick overviews.
Why Choose Wyze MicroSD Card?
Using the official Wyze MicroSD Card ensures compatibility and reliability with your Wyze Cam. Larger capacity cards like 128GB or 256GB provide longer recording times, making them ideal for continuous surveillance.
Wyze Cam v4: The Ideal Camera for 24/7 Local Storage
Product Highlights
The Wyze Cam v4 is a powerful security camera that supports local storage with microSD cards up to 512GB, making it perfect for continuous 24/7 recording.
  • Video Quality: Crystal-clear 2.5K QHD (2560x1440) resolution for sharp footage.
  • Field of View: Wide 115.8° diagonal view to cover more area.
  • Night Vision: Equipped with 4 IR LEDs and 2 white spotlight LEDs for color night vision.
  • Weather Resistance: Rated IP65, suitable for indoor and outdoor use.
  • Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for stable streaming.
  • Local Storage: Compatible with microSD cards up to 512GB for extensive local recording.
  • Additional Features: Two-way talk, built-in siren, noise echo cancellation, and Alexa/Google Assistant integration.
Included in the Box
  • Wyze Cam v4
  • Wall Mount Plate and Tape
  • Screw Kit
  • Indoor USB Power Adapter
  • 6-Foot Flat micro USB to USB-A Cable
The Wyze Cam v4 combined with a Wyze MicroSD Card offers a seamless way to record and store your home or business security footage locally, without monthly fees.
Home security with Wyze Cam v4
How to Set Up Local Storage on Your Wyze Cam for 24/7 Recording
Step 1: Choose and Insert Your Wyze MicroSD Card
Select the microSD card size that fits your recording needs. For 24/7 footage, larger cards like 128GB or 256GB are recommended.
  • Insert the microSD card into the slot on your Wyze Cam v4. The slot is usually located on the bottom or side of the camera, protected by a silicone flap.
Step 2: Format the MicroSD Card
  • Open the Wyze app and tap into your camera’s live stream.
  • Navigate to Settings > Advanced Settings > Manage MicroSD Card > Format.
  • Formatting erases all existing data, so back up any important files beforehand.
Step 3: Enable Local Recording
  • In the Wyze app, go to Settings > Advanced Settings.
  • Toggle on Record to MicroSD Card.
  • Choose between Continuous Recording for 24/7 footage or Events Only to save space by recording only motion-triggered events.
Step 4: View Your Recordings
  • From the live stream, tap View Playback to scroll through footage using the timeline or calendar.
  • Recorded segments are highlighted for easy navigation.
  • You can also remove the microSD card and view raw video files (MP4) on your computer.
Continuous local recording ensures your footage is saved even if your camera loses internet connection, providing peace of mind for home security.
Additional Tips for Optimal Use
  • Power Supply: For continuous recording, ensure your Wyze Cam v4 is connected to a stable power source to avoid interruptions.
  • Storage Management: When the microSD card is full, it automatically overwrites the oldest footage, so you always have the latest recordings.
  • Firmware Updates: Keep your Wyze Cam firmware updated for the best performance and compatibility with microSD cards.
  • Battery-Powered Cams: If using battery-powered Wyze cameras, continuous recording may drain the battery quickly; consider event-only recording or wired power options.
Summary
Adding local storage to your Wyze Cam with a Wyze MicroSD Card is a straightforward and cost-effective way to enable 24/7 continuous recording. The Wyze Cam v4 paired with a high-capacity Wyze MicroSD Card offers excellent video quality, reliable local storage, and advanced features to keep your home or business secure around the clock.
FeatureWyze MicroSD CardWyze Cam v4
Product TypeAccessories (Memory Card)Camera
PurposeContinuous recording and time lapses for Wyze CamsHome security camera with video recording
Storage Capacity Variants32GB microSDHC, 128GB microSDXC, 256GB microSDXCSupports microSD card up to 512GB
Price Range$8.99 - $29.99$35.98 - $100 (varies by bundle and variant)
RecordingLocal continuous recording on microSD card24/7 local recording with microSD card
Video ResolutionN/A (storage only)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
Weather ResistanceN/AIP65 rated (outdoor compatible)
ConnectivityN/AWi-Fi 6, Bluetooth 5.2
Audio FeaturesN/AEnhanced two-way talk, built-in siren
Motion DetectionN/AYes, with motion detection zones
Additional FeaturesNo monthly fees, timeline controls, timelapseMotion-activated spotlight, smoke & CO alerts, AI auto-zoom
CompatibilityCompatible with Wyze Cams with microSD slotWorks with Alexa, Google Assistant, IFTTT
Return Policy30-day hassle-free returns30-day hassle-free returns
How do I enable 24/7 continuous recording on my Wyze Cam?To enable 24/7 continuous recording on your Wyze Cam, insert a Wyze MicroSD Card into your camera, open the Wyze app, go to Settings > Advanced Settings, and toggle on 'Record to MicroSD Card.' Then, select 'Continuous Recording' to capture footage around the clock.
What sizes of Wyze MicroSD Cards are available for local storage?Wyze MicroSD Cards are available in 32GB, 128GB, and 256GB sizes. The Wyze Cam v4 also supports microSD cards up to 512GB, allowing for extended local recording.
Why should I use an official Wyze MicroSD Card with my Wyze Cam?Using an official Wyze MicroSD Card ensures optimal compatibility and reliability with your Wyze Cam, supporting features like continuous recording and time lapse without issues.
How do I insert and format a microSD card in my Wyze Cam v4?Insert the microSD card into the slot on your Wyze Cam v4, typically located on the bottom or side of the camera. In the Wyze app, go to Settings > Advanced Settings > Manage MicroSD Card > Format to prepare the card for use. Formatting will erase all existing data on the card.
Can I view my Wyze Cam recordings without an internet connection?Yes, with local storage enabled, your Wyze Cam saves footage directly to the microSD card. You can view recordings through the Wyze app or by removing the card and accessing the MP4 files on your computer, even if the camera loses internet connection.
How does the Wyze Cam v4 support local storage for security footage?The Wyze Cam v4 supports microSD cards up to 512GB, allowing for extensive local storage. It offers features like 2.5K QHD video, color night vision, and continuous or event-based recording, making it ideal for 24/7 security footage.
What happens when my Wyze MicroSD Card is full?When your Wyze MicroSD Card is full, the camera automatically overwrites the oldest footage, ensuring you always have the most recent recordings available.
Can I use continuous recording on battery-powered Wyze cameras?Continuous recording on battery-powered Wyze cameras is not recommended, as it can quickly drain the battery. For these models, consider using event-only recording or connecting the camera to a wired power source.
How do I view and manage my Wyze Cam recordings?To view recordings, open the Wyze app, access your camera’s live stream, and tap 'View Playback.' You can scroll through footage using the timeline or calendar. Alternatively, remove the microSD card and view the video files on your computer.
What are the benefits of using local storage with Wyze Cam?Local storage with a Wyze MicroSD Card allows for continuous 24/7 recording, offline access to footage, and no reliance on cloud storage or monthly fees. It also ensures your recordings are safe even if your internet connection is lost.
What are the different sizes of Wyze MicroSD Cards available for local storage?Can I use a non-Wyze MicroSD card with my Wyze Cam v4?How do I format the microSD card using the Wyze app?
