Best Home Security Cameras with Smart Detection and Smoke & CO Alerts
Protect your home with the latest smart security cameras that offer advanced detection features, including smoke and carbon monoxide (CO) alerts. Whether you want indoor or outdoor coverage, wired or wireless options, these Wyze cameras provide reliable, high-quality video surveillance combined with smart alerts to keep your family safe.
Wyze Cam OG – 1080p Camera with Spotlight & Smoke/CO Alerts
The Wyze Cam OG is a versatile indoor/outdoor security camera designed for quick response and clear monitoring. It features:
- 1080p Full HD video resolution with a CMOS-Starlight sensor for crisp images day and night.
- Built-in 40-lumen spotlight to illuminate dark areas and deter intruders.
- 3X faster notifications and improved two-way audio with noise and echo cancellation.
- Smart detection zones customizable to reduce false alerts.
- Smoke and CO alerts integrated directly into the camera system for immediate warnings.
- Weather resistance rated IP65, suitable for outdoor use in various climates.
- Supports up to 256 GB microSD local storage and works with Android 9.0+ and iOS 15.0+.
- Includes a 90-decibel user-activated siren for added security.
This camera is perfect for homeowners who want a reliable wired camera with smart safety alerts and spotlight functionality.
Wyze Cam v4 – 2.5K Indoor/Outdoor Camera with Enhanced Color Night Vision
For those seeking higher resolution and advanced night vision, the Wyze Cam v4 offers:
- 2.5K QHD video resolution (2560x1440) for crystal-clear footage.
- Enhanced color night vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens).
- Motion-activated spotlight to brighten scenes when movement is detected.
- Wi-Fi 6 support for faster and more stable connectivity.
- Local storage up to 512 GB microSD and optional cloud storage.
- Two-way audio with noise and echo cancellation.
- Built-in 99dB waterproof siren for alerting intruders.
- IP65 weather resistance for reliable outdoor use.
- Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
This camera is ideal for users who want premium video quality and smart home compatibility with robust outdoor durability.
Wyze Battery Cam Pro – 2.5K Wire-Free Outdoor Camera with Spotlight & Radar
Experience the freedom of wire-free installation with the Wyze Battery Cam Pro, featuring:
- 2.5K HDR video resolution with a wide 134° field of view.
- Integrated spotlight and siren with 187 lumens and 100 dB sound.
- Radar + PIR motion detection for precise and reliable alerts.
- Removable rechargeable battery packs offering up to 6 months of battery life.
- Supports both 2.4 GHz and 5 GHz Wi-Fi for flexible connectivity.
- IP65 weatherproof rating ensures performance in all weather conditions.
- Two-way audio with built-in speaker and microphone.
- Compatible with Alexa, Google Assistant, and IFTTT.
Perfect for outdoor areas where running wires is difficult, this camera combines high resolution, smart detection, and long battery life.
Wyze Cam Pan v3 – 360° Coverage with Night Vision and Smart Alerts
Cover every angle with the Wyze Cam Pan v3, a fully weather-resistant camera that offers:
- 360° horizontal and 180° vertical pan and tilt for complete room or yard coverage.
- 1080p HD video resolution with 4 IR LEDs for night vision.
- IP65 weather resistance for indoor/outdoor use (outdoor requires separate power adapter).
- Push notifications for motion alerts.
- Supports up to 256 GB microSD local storage.
- Integrates with Alexa, Google Assistant, and IFTTT.
Ideal for users who want dynamic camera movement and wide coverage with smart detection.
Wyze Cam Pan v3 offers weather-resistant 360° security coverage.
Wyze Bulb Cam – 2K Camera Built into a Smart LED Bulb
Combine lighting and security with the Wyze Bulb Cam, a unique 2-in-1 device that includes:
- 2K HD video resolution (2304 x 1296) with color night vision.
- 160° field of view for wide coverage.
- Smart LED bulb with up to 800 lumens brightness and 3000K color temperature.
- Motion-activated light and push notifications for instant alerts.
- Supports local storage up to 256 GB microSD (no subscription needed).
- Two-way audio with built-in microphone and speaker.
- Fits standard E26 sockets for easy installation.
- IP65 weather resistance for outdoor use.
This camera is perfect for those wanting discreet security combined with smart lighting control.
Wyze Bulb Cam blends security and lighting in one smart device.
Why Choose Wyze Smart Security Cameras?
Wyze cameras stand out with their combination of affordability, advanced smart detection, and integration of critical safety alerts like smoke and CO detection. Their weather-resistant designs and flexible mounting options make them suitable for any home environment, while features like two-way audio, spotlight illumination, and sirens enhance your security setup.
With options ranging from wired to wireless, fixed to pan-tilt, and even integrated lighting cameras, Wyze offers a comprehensive lineup to meet your home security needs.
Summary of Key Features
Product | Resolution | Smart Detection | Smoke/CO Alerts | Spotlight | Two-Way Audio | Weather Resistant | Storage Support |
Wyze Cam OG | 1080p | Yes | Yes | Yes | Yes | IP65 | Up to 256 GB microSD |
Wyze Cam v4 | 2.5K QHD | Yes | No | Yes | Yes | IP65 | Up to 512 GB microSD |
Wyze Battery Cam Pro | 2.5K HDR | Radar + PIR | No | Yes | Yes | IP65 | Up to 256 GB microSD |
Wyze Cam Pan v3 | 1080p | Yes | No | No | Yes | IP65 | Up to 256 GB microSD |
Wyze Bulb Cam | 2K | Yes | No | Yes | Yes | IP65 | Up to 256 GB microSD |
*Smoke and CO alerts are currently supported specifically by Wyze Cam OG.
Protect your home with smart, reliable Wyze security cameras that keep you informed and safe around the clock.
What are the best Wyze home security cameras with smoke and carbon monoxide (CO) alerts?
The Wyze Cam OG is the best Wyze home security camera with integrated smoke and carbon monoxide (CO) alerts. It provides immediate warnings for smoke and CO detection, making it ideal for enhanced home safety.Which Wyze security cameras offer smart detection features?
All Wyze security cameras featured—Wyze Cam OG, Wyze Cam v4, Wyze Battery Cam Pro, Wyze Cam Pan v3, and Wyze Bulb Cam—offer smart detection features such as customizable detection zones, motion detection, and advanced alert systems. The Wyze Battery Cam Pro also includes radar and PIR motion detection for precise alerts.Are Wyze security cameras suitable for outdoor use?
Yes, all the listed Wyze security cameras are IP65 weather-resistant, making them suitable for both indoor and outdoor use. This includes the Wyze Cam OG, Wyze Cam v4, Wyze Battery Cam Pro, Wyze Cam Pan v3 (with outdoor power adapter), and Wyze Bulb Cam.Which Wyze camera is best for high-resolution video and color night vision?
The Wyze Cam v4 and Wyze Battery Cam Pro both offer 2.5K high-resolution video. The Wyze Cam v4 features enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, providing crystal-clear footage even in low-light conditions.Do Wyze security cameras support local storage?
Yes, all Wyze security cameras support local storage via microSD cards. Wyze Cam OG, Wyze Cam Pan v3, Wyze Battery Cam Pro, and Wyze Bulb Cam support up to 256 GB, while Wyze Cam v4 supports up to 512 GB microSD cards.Can Wyze security cameras be integrated with smart home systems?
Yes, Wyze security cameras are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.Which Wyze camera is best for wire-free outdoor installation?
The Wyze Battery Cam Pro is the best option for wire-free outdoor installation. It features a removable rechargeable battery pack with up to 6 months of battery life, 2.5K HDR video, and radar + PIR motion detection.What is the advantage of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical pan and tilt, providing complete room or yard coverage. It is weather-resistant, supports two-way audio, and delivers smart motion alerts for dynamic security monitoring.What makes the Wyze Bulb Cam unique among security cameras?
The Wyze Bulb Cam combines a 2K HD security camera with a smart LED bulb, offering both lighting and surveillance in one device. It features a 160° field of view, color night vision, motion-activated lighting, and easy installation in standard E26 sockets.Do Wyze security cameras require a subscription for storage?
No, Wyze security cameras support local storage via microSD cards without requiring a subscription. However, optional cloud storage is available for users who prefer cloud-based video backup.What are the key features of Wyze security cameras?
Key features of Wyze security cameras include high-definition video (up to 2.5K), smart detection zones, two-way audio, integrated spotlights and sirens, weather resistance (IP65), local and optional cloud storage, and compatibility with smart home platforms.
