High Resolution Security Cameras with Wi-Fi 6 and Free MicroSD Card
Looking for a high-resolution security camera that supports the latest Wi-Fi 6 technology and comes with a free microSD card for local storage? Discover the Wyze Cam v4 bundle, the perfect solution for crystal-clear home security with advanced connectivity and storage options. This page highlights the best Wyze products tailored to your needs, including the Wyze Cam v4 with free 32GB microSD card and the standalone Wyze MicroSD cards for extended recording.
Wyze Cam v4 + FREE 32GB MicroSD Card: Ultimate Security with Wi-Fi 6
Experience unmatched home security with the
Wyze Cam v4, now bundled with a
free 32GB microSD card for continuous local recording. This camera is designed to deliver stunning video quality and smart features that keep your home safe day and night.
Key Features:
- 2.5K QHD Resolution: Capture crystal-clear video with 2560x1440 pixels, providing four times the detail of 720p HD.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection with the latest Wi-Fi 6 technology, ensuring smooth streaming and faster data transfer.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware that outperforms traditional night vision.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders and improving video clarity.
- 24/7 Local Recording: With the included 32GB microSD card, record continuously without monthly fees.
- Smart Home Compatibility: Works seamlessly with Alexa and Google Assistant for voice control and automation.
- Multiple Mounting Options: Install easily on walls, ceilings, or use the magnetic mount for flexible placement.
Specifications:
- Video Resolution: 2.5K QHD (2560x1440)
- Field of View: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
- Sensor: CMOS Starlight Sensor
- Night Vision: 4 IR LEDs + 2 white spotlight LEDs
- Dimensions: 2in x 2in x 2 3/8in
- Weight: 0.49 lb (222 g)
- Power: Wired with 6-foot micro USB cable
- Storage: Supports microSD cards up to 512GB
"The clearest Wyze Cam ever made, now with free local storage and Wi-Fi 6 connectivity."
Wyze MicroSD Card: Expand Your Storage for Continuous Recording
Unlock the full potential of your Wyze Cam with the
Wyze MicroSD Card series, designed specifically for Wyze cameras to enable continuous local recording and time-lapse videos.
Why Choose Wyze MicroSD Cards?
- Seamless Integration: Perfectly compatible with Wyze Cams for hassle-free setup.
- Multiple Sizes Available: Choose from 32GB, 128GB, or 256GB to fit your recording needs.
- No Monthly Fees: Store your footage locally without recurring costs.
- Easy Playback: Access recorded videos anytime via the Wyze app or by removing the card.
- Supports Time-Lapse: Create stunning time-lapse videos of your environment.
Specifications:
- Sizes: 32GB microSDHC, 128GB microSDXC, 256GB microSDXC
- Compatible with all Wyze cameras featuring microSD slots
- Supports continuous recording and time-lapse capture
"Unlock continuous recording and time lapses for Wyze Cams."
Why Choose Wyze Cam v4 for Your Security Needs?
The Wyze Cam v4 stands out as a top choice for those seeking high-resolution video, advanced night vision, and the latest Wi-Fi 6 technology. Whether you want to monitor your home, pets, or property, this camera offers:
- Superior Image Quality: 2.5K QHD resolution ensures you never miss a detail.
- Reliable Connectivity: Wi-Fi 6 support means better range and less interference.
- Smart Alerts: Motion and sound detection with customizable zones.
- Safety Alerts: Receive notifications for smoke and CO alarms.
- Voice Assistant Integration: Control your camera hands-free with Alexa or Google Assistant.
Enhance Your Security Setup with Wyze Battery Cam Pro
For those who prefer a wire-free option with high resolution and Wi-Fi 6 capabilities, the
Wyze Battery Cam Pro offers:
- 2.5K HDR Video Resolution: Crisp and clear footage day or night.
- Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for flexible placement.
- Integrated Spotlight & Siren: Deter unwanted visitors with bright lights and loud siren.
- Radar + PIR Motion Detection: Advanced sensors for accurate motion alerts.
- Long Battery Life: Up to 6 months on a single charge with removable, rechargeable batteries.
- Weatherproof Design: IP65 rating for reliable outdoor use.
This camera is ideal for locations without easy access to power outlets, providing flexible and powerful security coverage.
Lifestyle Image: Wyze Cam Pan v3 in Action
Wyze Cam Pan v3 providing weather-resistant outdoor security in snowy conditions.
Summary
For high-resolution security cameras with Wi-Fi 6 and free microSD card storage, the
Wyze Cam v4 + FREE 32GB MicroSD Card bundle is the best value and feature-packed option. Complement your setup with additional Wyze MicroSD cards for extended recording or choose the wireless
Wyze Battery Cam Pro for flexible placement without sacrificing video quality.
Secure your home with crystal-clear video, smart alerts, and reliable connectivity today.
What is included in the Wyze Cam v4 + FREE 32GB MicroSD Card bundle?
The Wyze Cam v4 bundle includes the high-resolution Wyze Cam v4 security camera and a free 32GB microSD card for continuous local recording, allowing you to store footage without monthly fees.Does the Wyze Cam v4 support Wi-Fi 6?
Yes, the Wyze Cam v4 supports the latest Wi-Fi 6 technology, providing a stronger, more reliable connection for smooth video streaming and faster data transfer.What video resolution does the Wyze Cam v4 offer?
The Wyze Cam v4 delivers 2.5K QHD resolution (2560x1440 pixels), offering four times the detail of standard 720p HD cameras for crystal-clear video quality.Can I use larger microSD cards with the Wyze Cam v4?
Yes, the Wyze Cam v4 supports microSD cards up to 512GB, allowing for extended continuous recording and storage.What are the key features of the Wyze Cam v4?
Key features of the Wyze Cam v4 include 2.5K QHD resolution, Wi-Fi 6 support, enhanced color night vision, motion-activated spotlight, 24/7 local recording, smart home compatibility with Alexa and Google Assistant, and multiple mounting options.Is the Wyze Cam v4 compatible with Alexa and Google Assistant?
Yes, the Wyze Cam v4 works seamlessly with both Alexa and Google Assistant, enabling voice control and smart home automation.What sizes are available for Wyze MicroSD cards?
Wyze MicroSD cards are available in 32GB, 128GB, and 256GB sizes, providing flexible storage options for continuous recording and time-lapse videos.Do Wyze MicroSD cards require a subscription for storage?
No, Wyze MicroSD cards allow you to store your footage locally on the card without any monthly fees or subscriptions.How can I access recorded videos from my Wyze Cam?
You can access recorded videos anytime through the Wyze app or by removing the microSD card and viewing the footage on a compatible device.What is the Wyze Battery Cam Pro and how is it different?
The Wyze Battery Cam Pro is a wire-free security camera featuring 2.5K HDR video resolution, dual-band Wi-Fi (2.4 GHz and 5 GHz), integrated spotlight and siren, radar and PIR motion detection, long battery life, and weatherproof design, making it ideal for flexible outdoor placement.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is weather-resistant and can provide reliable outdoor security, even in snowy or harsh conditions.What are the benefits of using Wyze MicroSD cards with Wyze cameras?
Wyze MicroSD cards are designed for seamless integration with Wyze cameras, enabling continuous local recording, easy playback, and the ability to create time-lapse videos without recurring costs.
