Secure Your Wyze Camera with High Adhesion Window Mount for Clear, Glare-Free Views
We recommend the Wyze Window Mount for your needs. This accessory is designed to securely attach your Wyze Cam v3, Cam v3 Pro, Cam v4, Wyze Cam OG, or Wyze Cam OG Telephoto to a window, providing a clear view free of glare or reflection. Here are some key features:
  • High Adhesion: The mount is specifically designed to adhere securely to glass surfaces, ensuring your camera stays in place.
  • Compatibility: Works with a range of Wyze cameras, including the Wyze Cam v3, v3 Pro, v4, and the Wyze Cam OG series.
  • Clear View: Enjoy a clear view without glare or reflection, enhancing your exterior security setup.
This mount is perfect for those looking to upgrade their exterior security with a reliable and effective solution.
Can you tell me more about the compatibility of the Wyze Window Mount with different Wyze cameras?What surfaces can the Wyze Window Mount adhere to securely?What is the return policy for the Wyze Window Mount?
