For those seeking a solar panel that can withstand both heat and cold to support their Wyze Cam throughout the year, we recommend the Wyze Battery Cam Solar Panel. This accessory is specifically designed to extend the battery life of your Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2, ensuring reliable performance in various weather conditions. Here are some key features:
- Weather Resistant: The Wyze Battery Cam Solar Panel is IP65 weather resistant, making it suitable for outdoor use in different climates, including both hot and cold environments.
- Flexible Installation: It includes an easy 360° mount and a 13-foot power cable, allowing for flexible and optimal placement to capture maximum sunlight.
- Efficient Solar Power: With a solar power rating of 2.5W, 5VDC, it efficiently converts sunlight into electrical energy to keep your camera charged.
- Durable Design: The panel features a robust design with a white frame and mount, along with black solar cells, ensuring durability against the elements.
Additionally, for a comprehensive security solution, consider the Wyze Battery Cam Pro + Solar Panel bundle. This package includes the Wyze Battery Cam Pro, which offers 2.5K HDR video resolution, wire-free operation, and integrated spotlight and siren features. It is also IP65 weatherproof, making it an excellent choice for year-round security.
