HD Video Doorbells with Wide Field of View for Package Security
When it comes to securing your front porch and ensuring your packages are safe, having a high-definition video doorbell with a wide field of view is essential. Wyze offers a range of smart video doorbells designed to provide crystal-clear video, broad coverage angles, and intelligent features tailored for package security and home safety. Below, we explore the top Wyze video doorbells that combine HD video quality with wide viewing angles to keep your doorstep secure.
Wyze Video Doorbell v2: Exceptional 2K Video and Wide Coverage
Experience the clearest wired video doorbell from Wyze with the Wyze Video Doorbell v2. This model delivers stunning 2K resolution (2048 x 1536) video, allowing you to see every detail of your front porch and packages with remarkable clarity.
Key Features:
  • 2K Video Resolution: Capture sharp, detailed video footage day and night.
  • Wide Field of View: A diagonal field of view of 166.8°, with 135° horizontal and 103° vertical coverage, minimizing blind spots.
  • Motion-Activated Voice Deterrence: Automatically warns visitors or potential intruders with a recorded message.
  • Two-Way Audio: Communicate directly through the doorbell from anywhere using your smartphone.
  • Local and Cloud Storage: Supports up to 256GB microSD card for local storage and optional cloud storage with Wyze Security Plan.
  • Weather Resistant: IP65 rating ensures reliable operation in rain, snow, or heat.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Dimensions & Build:
  • Compact size: 4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)
  • Durable polycarbonate body with resin lens and CMOS Starlight sensor for superior low-light performance.
This doorbell is perfect for homeowners who want a wired solution with ultra-wide viewing angles to monitor packages and visitors effectively. Wyze Video Doorbell v2 Lifestyle Wyze Video Doorbell v2 installed on a front porch, capturing wide-angle HD video.
The Front Porch Security Bundle: All-in-One Porch Protection
For those seeking a comprehensive front porch security solution, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Chime for enhanced control and monitoring.
Bundle Highlights:
  • 1080p HD Video Doorbell: View your porch in crisp 1080p resolution with two-way audio.
  • Remote Lock Control: Lock or unlock your door remotely and monitor lock history via the Wyze app.
  • Motion Event Alerts: Receive notifications for motion events and door activity.
  • Smart Assistant Compatibility: Works with Alexa and Google Assistant for voice commands.
  • Weather Resistant Doorbell: IP65 rating ensures durability in all weather conditions.
This bundle is ideal for users who want to secure both their door and porch area with integrated smart home features.
Wyze Video Doorbell Pro: Wider View and Flexible Power Options
The Wyze Video Doorbell Pro offers a wider ultra-wide viewing angle and the flexibility of wired or battery power, making installation quick and adaptable.
Standout Features:
  • Ultra-Wide Viewing Angle: Covers more area around your front door for better package and visitor monitoring.
  • Crystal-Clear HD Video: High-definition video quality ensures you never miss a detail.
  • Smart Detection Alerts: Includes person, package, vehicle, and pet detection with Cam Plus subscription.
  • Motion-Activated Security Light: Enhances visibility and deters unwanted visitors.
  • Two-Way Audio: Communicate instantly with visitors.
  • Easy Installation: Mount with screws or adhesive plate in just 30 seconds.
  • Chime Included: Comes with a dual-band Wi-Fi extender chime for faster notifications.
  • Smart Home Integration: Compatible with Alexa and Google Assistant.
This doorbell is perfect for those who want a versatile, battery-powered option with advanced detection features and a wide field of view. Wyze Video Doorbell Pro Lifestyle Wyze Video Doorbell Pro installed on a modern home, showcasing its sleek design and wide coverage.
Wyze Duo Cam Battery Doorbell: Dual Cameras for Ultimate Package Security
For the most advanced package security, the Wyze Duo Cam Battery Doorbell features dual cameras to monitor both people and packages simultaneously.
Features That Protect Your Packages:
  • Dual Camera Views: Front camera with 2K resolution and 132° horizontal field of view; bottom camera with 1080p resolution and 121° horizontal view to capture packages on the ground.
  • 2K Video Quality: Front camera delivers crisp, detailed video.
  • 8x Digital Zoom: Zoom in on suspicious activity or packages.
  • Two-Way Audio & Siren: Communicate with visitors and deter intruders with a 90 dB siren.
  • Motion-Activated Voice Warning: Alerts visitors they are being recorded.
  • Battery or Hardwired Power: Flexible power options with removable battery pack and USB-C charging.
  • Local and Cloud Storage: Supports up to 256GB microSD card and cloud storage.
  • Weather Resistant: IP65 rating for all-weather durability.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
This doorbell is the ultimate choice for homeowners who want comprehensive coverage of their porch and packages with dual-camera technology. Wyze Duo Cam Doorbell Lifestyle Wyze Duo Cam Doorbell capturing both front door and package area with dual cameras.
Enhance Your Doorbell’s Field of View with the Wyze Video Doorbell v2 Wedge Kit
If your porch or door frame is angled, the Wyze Video Doorbell v2 Wedge Kit is the perfect accessory to adjust your doorbell’s viewing angle for maximum coverage.
Benefits:
  • Includes 15° horizontal and 7.5° vertical brackets to eliminate blind spots.
  • Quick and easy installation.
  • Weather resistant and durable plastic construction.
  • Compatible exclusively with Wyze Video Doorbell v2.
This accessory ensures you get the best possible field of view for your Wyze Video Doorbell v2, enhancing package security.
Why Choose Wyze Video Doorbells for Package Security?
Wyze video doorbells combine high-definition video, wide-angle lenses, and smart detection features to provide comprehensive front porch security. Whether you want wired reliability or battery-powered flexibility, Wyze offers solutions that fit your home and security needs. With two-way audio, motion alerts, and integration with popular smart home assistants, you can monitor and protect your packages from anywhere, anytime.
Summary of Featured Products
Product NameVideo ResolutionField of View (Horizontal)Power TypeSpecial Features
Wyze Video Doorbell v22K (2048x1536)135°Wired (16V-24V AC)Motion voice deterrence, 2-way audio
Front Porch Security Bundle1080p HD88°WiredIncludes Wyze Lock, remote lock control
Wyze Video Doorbell ProHDUltra-wide (not specified)Wired or BatteryMotion-activated light, smart detection
Wyze Duo Cam Battery DoorbellFront 2K / Bottom 1080pFront 132°, Bottom 121°Battery or WiredDual cameras, package detection, siren
Wyze Video Doorbell v2 Wedge KitN/AAdjustable angleAccessoryAngle adjustment for better coverage
Secure your home and packages with Wyze’s advanced HD video doorbells featuring wide fields of view and smart security features designed for modern homeowners.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell ProWyze Duo Cam Battery Doorbell
Video Resolution2K (2048 x 1536)1080p HD (Doorbell)HD (exact resolution not specified)Front: 2K (2048 x 1536), Bottom: 1080p
Video Quality2K, color night vision with starlight sensor1080p HDCrystal-clear HD2K front camera, 1080p bottom camera
PowerWired (16V-24V AC)Wyze Lock (smart lock) + Wired DoorbellWired or BatteryBattery or Hardwired
Local StoragemicroSD slot (up to 256GB)Not specifiedNot specifiedmicroSD support up to 256GB (sold separately)
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionAWS Cloud storage
Two-Way AudioYesYesYesYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Not specifiedYesYes
Field of View135° horizontal, 103° vertical approx.Not specifiedUltra-wide viewing angleFront: 132° horizontal, 100° vertical; Bottom: 121° horizontal, 60° vertical
Chime IncludedYes (Chime Controller included)Yes (Wyze Video Doorbell and Chime included)YesYes (Wyze Wi-Fi Chime included)
Smart FeaturesAI person detection (with Cam Plus), real-time alerts, pre-roll recordingAI person detection, lock/unlock integration with Wyze LockPerson, package, vehicle, pet detection with Cam PlusAI detections and alerts, two camera views
Weather ResistanceIP65IP65 (implied by included devices)Not explicitly stated, but suitable for outdoorIP65
InstallationWired installation, includes wedge for angle adjustmentBundle includes multiple devices, installation variesWired or wireless, install in 30 secondsBattery powered, hardwired optional
Additional FeaturesWorks with Alexa and Google Home, motion-activated voice deterrence, pre-roll recordingRemote lock/unlock via app, lock history, two-way audioMotion-activated security light, 20 chime tunes, dual-band Wi-Fi extender chimeDual camera views, removable battery pack, USB-C charging
Price$44.98$123.99 - $173.97 (varies by variant)$99.98$89.98 - $109.99
What are the benefits of using a Wyze HD video doorbell for package security?Wyze HD video doorbells offer high-definition video quality, wide-angle lenses, and smart detection features to provide comprehensive front porch and package security. With features like motion alerts, two-way audio, and integration with Alexa and Google Assistant, you can monitor and protect your packages from anywhere.
Which Wyze video doorbell has the widest field of view?The Wyze Video Doorbell v2 offers a diagonal field of view of 166.8°, with 135° horizontal and 103° vertical coverage, minimizing blind spots. The Wyze Video Doorbell Pro also provides an ultra-wide viewing angle for extensive coverage around your front door.
What is the video resolution of Wyze Video Doorbell v2?The Wyze Video Doorbell v2 delivers stunning 2K resolution (2048 x 1536), allowing you to see every detail of your front porch and packages with remarkable clarity.
Can I use Wyze video doorbells in all weather conditions?Yes, all Wyze video doorbells featured are IP65 weather resistant, ensuring reliable operation in rain, snow, or heat.
What smart home systems are Wyze video doorbells compatible with?Wyze video doorbells are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home system.
Does Wyze offer a battery-powered video doorbell option?Yes, the Wyze Video Doorbell Pro and Wyze Duo Cam Battery Doorbell both offer battery-powered options, providing flexible installation without the need for existing doorbell wiring.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a 1080p HD video doorbell, Wyze Lock for remote lock control, and a chime. It provides comprehensive porch protection with motion event alerts and smart assistant compatibility.
How does the Wyze Duo Cam Battery Doorbell enhance package security?The Wyze Duo Cam Battery Doorbell features dual cameras: a front camera with 2K resolution and a bottom camera with 1080p resolution. This setup allows you to monitor both visitors and packages on the ground simultaneously, ensuring ultimate package security.
Can I store video footage locally with Wyze video doorbells?Yes, Wyze video doorbells support local storage with microSD cards (up to 256GB on select models) and also offer optional cloud storage with the Wyze Security Plan.
What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?The Wyze Video Doorbell v2 Wedge Kit allows you to adjust your doorbell’s viewing angle by 15° horizontally and 7.5° vertically, eliminating blind spots and maximizing coverage, especially if your porch or door frame is angled.
Do Wyze video doorbells have two-way audio?Yes, all featured Wyze video doorbells include two-way audio, allowing you to communicate directly with visitors through your smartphone.
What advanced detection features are available with Wyze video doorbells?Wyze video doorbells offer smart detection features such as person, package, vehicle, and pet detection (with Cam Plus subscription), as well as motion-activated voice deterrence and security lights on select models.
How easy is it to install a Wyze video doorbell?Wyze video doorbells are designed for easy installation. The Wyze Video Doorbell Pro, for example, can be mounted with screws or an adhesive plate in just 30 seconds, and comes with a chime that also acts as a Wi-Fi extender.
What are the key features of the Wyze Video Doorbell v2?Can you tell me more about the Front Porch Security Bundle?Do you have any deals, ongoing sales, discounts, or promotions for the video doorbells?
