Optimize Your Wyze Camera's Performance: Overcome Direct Sunlight Issues with the Wyze Window Mount
When mounting your Wyze Cam using the Wyze Window Mount, you can enjoy a clear view free of glare or reflection, which is particularly beneficial in handling direct sunlight issues. This accessory is designed to reduce glare by securely attaching your Wyze Cam v3, v3 Pro, v4, or Cam OG series to a glass surface, ensuring optimal visibility and security. Wyze Window Mount: Reduces glare, Mounts on glass surface, Clear view free of glare or reflection.
How does the Wyze Window Mount ensure optimal visibility for the camera?Can the Wyze Window Mount be used with all Wyze camera models?What surfaces can the Wyze Window Mount be attached to?
