Advanced Home Camera Bundles with Pan-Tilt & Two-Way Audio
Advanced Home Camera Bundles with Pan Tilt Tracking and Two-Way Audio
Looking for a comprehensive home security solution that offers advanced features like pan-tilt tracking and two-way audio? Explore the best Wyze camera bundles designed to keep your home safe, monitored, and connected with crystal-clear video and smart functionalities. Whether you want outdoor surveillance or a full home security setup, these bundles provide everything you need for peace of mind.
Wyze Cam Pan v3 + Lamp Socket v2 Bundle: Smart Pan-Tilt Tracking with Easy Power
Key Features:
  • Pan and Tilt Functionality: The Wyze Cam Pan v3 offers smooth 360° horizontal rotation and 93° vertical tilt, allowing you to track movement across wide areas effortlessly.
  • Two-Way Audio: Communicate directly through the camera with built-in microphone and speaker, perfect for greeting visitors or deterring intruders.
  • Lamp Socket Power: The included Lamp Socket v2 lets you power your Pan v3 camera directly from any standard E26 light socket without needing an outlet, simplifying installation.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for reliable connection.
  • Compatibility: Works seamlessly with Android 7.0+ and iOS 12.0+ devices.
  • Durability: Suitable for damp locations, though not fully weatherproof, ideal for covered outdoor areas.
This bundle is perfect for those who want a flexible, motorized camera with easy power options integrated into existing lighting fixtures.
Wyze Cam v4 Outdoor Bundle: Crystal-Clear 2.5K QHD with Enhanced Night Vision
Why Choose Wyze Cam v4 Outdoor Bundle?
  • 2.5K Quad HD Resolution: Capture stunningly detailed video with 2.5K QHD clarity, providing sharper images than ever before.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware that outperforms traditional night vision.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, improving visibility and deterring unwanted visitors.
  • Two-Way Audio: Talk and listen through the camera using the Wyze app, enabling real-time communication.
  • 24/7 Local Recording: Continuous recording with a built-in microSD card slot (128GB included in the bundle) ensures you never miss a moment.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection with compatible routers.
  • Smart Alerts: Receive notifications for motion, sound, and even smoke or CO alarms.
  • Outdoor Ready: Designed to withstand rain, snow, and shine when paired with the Wyze Outdoor Power Adapter included in the bundle.
This bundle is ideal for outdoor security enthusiasts who want high-resolution video, smart detection, and reliable power for continuous monitoring.
Whole Home Security Starter Kit: Comprehensive Protection with Pan-Tilt and Two-Way Audio
What’s Included:
  • Wyze Cam v4: The latest in Wyze’s lineup with 2.5K QHD video, color night vision, and two-way audio.
  • Wyze Video Doorbell v2: Adds an extra layer of security at your front door with HD video and two-way talk.
  • Wyze Home Monitoring Starter Kit: Includes sensors and alarms to protect doors and windows.
Benefits:
  • All-in-One Security: Covers indoor and outdoor areas with pan-tilt camera capabilities and smart alerts.
  • Two-Way Communication: Speak directly through cameras and doorbell to interact with visitors or delivery personnel.
  • Easy Setup: Integrates seamlessly with the Wyze app for remote monitoring and control.
  • Multiple Color Options: Available in White, Grey, and Black to match your home’s aesthetic.
This starter kit is perfect for homeowners seeking a robust, easy-to-install security system with pan-tilt tracking and two-way audio communication.
Enhance Your Home Lighting and Security with Lamp Socket Bundles
Cam v4 + Lamp Socket v2 Bundle
  • Power your Wyze Cam v4 directly from a lamp socket.
  • Features motion-activated lights and dusk-to-dawn scheduling.
  • Compatible with multiple Wyze cameras including Pan v3 and Cam v4.
  • Ideal for locations without convenient power outlets.
  • Provides the same convenient power solution for the Pan v3 camera.
  • Enables smart lighting integration with your security camera.
  • Supports two-way audio and pan-tilt tracking while simplifying installation.
Why Choose Wyze Advanced Camera Bundles?
Wyze offers cutting-edge home security solutions with features like pan-tilt tracking, two-way audio, and enhanced night vision. Their bundles come with everything you need for easy installation, reliable power, and smart alerts, making your home safer and smarter.
Home Security Camera in Use Alt text: Family monitoring home security cameras with smartphone app
Summary of Recommended Bundles for Advanced Home Security
Bundle NamePan-Tilt TrackingTwo-Way AudioOutdoor ReadyPower SolutionPrice Range
Wyze Cam Pan v3 + Lamp SocketYesYesDamp locationsLamp Socket (E26)$53.96
Wyze Cam v4 Outdoor BundleNo (fixed camera)YesYesOutdoor Power Adapter (Included)$69.99
Whole Home Security Starter KitYes (Cam v4)YesYesStandard Power$155.95+
Protect your home with the latest Wyze camera bundles featuring pan-tilt tracking and two-way audio. Choose the perfect setup for your needs and enjoy smart, reliable home security today.
Feature / ProductWyze Cam v4 Outdoor BundlePan v3 + Lamp Socket v2 BundleWhole Home Security Starter Kit
Price$69.99$53.96$155.95
Included Items1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x Wyze MicroSD Card 128GB1x Pan v3 compatible Lamp Socket v21x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter Kit
Camera TypeWyze Cam v4 (Color: Black, Grey, White)Wyze Cam Pan v3 compatible lamp socket (Black, White)Wyze Cam v4 (Black, Grey, White)
Camera Resolution2.5K QHD (2560x1440)N/A (lamp socket only)Wyze Cam v4: 2.5K QHD
Night VisionEnhanced Color Night VisionN/AWyze Cam v4: Enhanced Color Night Vision
Motion-Activated SpotlightYesNoWyze Cam v4: Yes
Power SourceWired with Outdoor Power AdapterPowers Pan v3 camera via lamp socketWired (Wyze Cam v4), Doorbell powered separately
Weather ResistanceIP65 (camera), Outdoor Power Adapter IP67Not weatherproof (lamp socket suitable for damp locations)Wyze Cam v4: IP65
ConnectivityWi-Fi 6, 2.4 GHz Wi-Fi802.11 b/g/n 2.4GHz, BluetoothWyze Cam v4: Wi-Fi 6, 2.4 GHz Wi-Fi
Smart Home IntegrationAlexa, Google AssistantN/AWyze Cam v4: Alexa, Google Assistant
Local StoragemicroSD card slot (128GB included)N/AN/A
Additional Features24/7 local recording, motion & sound detection, smoke & CO alertsMotion-activated lights, dusk to dawn schedulingIncludes Video Doorbell v2 and Home Monitoring Kit
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic mountN/AWyze Cam v4 mounting options
Warranty1 Year1 YearN/A
What features do Wyze advanced home camera bundles offer?Wyze advanced home camera bundles provide features such as pan-tilt tracking, two-way audio, enhanced night vision, motion-activated spotlights, and smart alerts. These bundles are designed for easy installation, reliable power solutions, and seamless integration with the Wyze app for remote monitoring.
How does pan-tilt tracking work on Wyze cameras?Pan-tilt tracking on Wyze cameras, such as the Wyze Cam Pan v3, allows the camera to rotate 360° horizontally and tilt 93° vertically. This enables the camera to follow movement across wide areas, ensuring comprehensive coverage and improved security.
What is two-way audio and how can I use it with Wyze cameras?Two-way audio lets you communicate through your Wyze camera using the built-in microphone and speaker. You can greet visitors, talk to delivery personnel, or deter intruders directly from the Wyze app on your smartphone.
Are Wyze camera bundles suitable for outdoor use?Yes, certain Wyze camera bundles, like the Wyze Cam v4 Outdoor Bundle, are designed for outdoor use and can withstand rain, snow, and sun when paired with the included Wyze Outdoor Power Adapter. The Wyze Cam Pan v3 is suitable for damp locations, making it ideal for covered outdoor areas.
What is included in the Wyze Cam Pan v3 + Lamp Socket v2 Bundle?The Wyze Cam Pan v3 + Lamp Socket v2 Bundle includes a motorized pan-tilt camera with two-way audio and a Lamp Socket v2, allowing you to power the camera directly from a standard E26 light socket. This bundle simplifies installation and is perfect for areas without convenient power outlets.
What are the benefits of the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD video resolution, enhanced color night vision, motion-activated spotlight, two-way audio, 24/7 local recording with a 128GB microSD card, Wi-Fi 6 support, and smart alerts for motion, sound, and smoke or CO alarms.
What does the Whole Home Security Starter Kit include?The Whole Home Security Starter Kit includes a Wyze Cam v4 with pan-tilt and two-way audio, a Wyze Video Doorbell v2 with HD video and two-way talk, and a Wyze Home Monitoring Starter Kit with sensors and alarms for doors and windows. It provides comprehensive protection for both indoor and outdoor areas.
How do Wyze Lamp Socket Bundles enhance home security?Wyze Lamp Socket Bundles allow you to power your Wyze cameras directly from a lamp socket, making installation easy in locations without power outlets. They also feature motion-activated lighting and dusk-to-dawn scheduling, enhancing both security and convenience.
Are Wyze cameras compatible with my smartphone?Wyze cameras are compatible with Android devices running version 7.0 or higher and iOS devices running version 12.0 or higher. You can control and monitor your cameras remotely using the Wyze app.
What power solutions are available for Wyze camera bundles?Wyze camera bundles offer various power solutions, including lamp socket adapters for easy installation in light fixtures, outdoor power adapters for weather-resistant setups, and standard power options for indoor use.
Do Wyze camera bundles support continuous recording?Yes, select Wyze camera bundles, such as the Wyze Cam v4 Outdoor Bundle, support 24/7 local recording with a built-in microSD card slot. The bundle includes a 128GB microSD card to ensure you never miss important footage.
Can I receive smart alerts from Wyze cameras?Yes, Wyze cameras provide smart alerts for motion, sound, and even smoke or CO alarms. These notifications are sent directly to your smartphone via the Wyze app, keeping you informed of any unusual activity.
Are Wyze camera bundles easy to install?Wyze camera bundles are designed for easy installation, with options like lamp socket adapters and outdoor power adapters included. The Wyze app guides you through the setup process for quick and hassle-free installation.
What color options are available for Wyze camera bundles?Wyze camera bundles, such as the Whole Home Security Starter Kit, are available in multiple color options including White, Grey, and Black to match your home’s aesthetic.
Can you tell me more about the features of the Wyze Cam v4 Outdoor Bundle?What is the difference between the Wyze Cam Pan v3 and the Wyze Cam v4?Are there any ongoing sales or discounts for the camera bundles?
