Front Door Smart Doorbells with Facial Recognition Capability
Enhance your home security with the latest front door smart doorbells that offer advanced facial recognition and intelligent monitoring features. Whether you want wired or wireless options, high-resolution video, or integrated smart home controls, these Wyze smart doorbells provide reliable, clear, and secure solutions to keep your front porch safe and connected.
Wyze Video Doorbell v2: Wired 2K Video Doorbell with Advanced Features
Experience crystal-clear 2K video resolution (2048 x 1536) with the Wyze Video Doorbell v2, designed for wired installation to ensure continuous power and reliable performance. This doorbell features a CMOS Starlight Sensor and a wide 166.8° diagonal field of view, capturing every detail from your doorstep.
Key Features:
- 2K HD Video & Local Storage: Capture every moment in stunning detail with local microSD storage support up to 256GB.
- Two-Way Audio & Voice Deterrence: Communicate with visitors or deter unwanted guests with motion-activated voice alerts.
- Wide Field of View: 135° horizontal and 103° vertical angles provide comprehensive coverage.
- Weather Resistant: IP65 rating ensures durability in all weather conditions.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
- Included Accessories: Comes with a chime controller, wall plate, wedge for angled mounting, and installation kit.
This wired doorbell is perfect for homeowners seeking high-quality video and dependable wired power with smart home compatibility.
Wyze Video Doorbell v2 installed on a front porch
The Front Porch Security Bundle: All-in-One Smart Doorbell and Lock Solution
For a comprehensive front door security upgrade, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Chime, offering a complete smart access management system.
Bundle Highlights:
- 1080p HD Video Doorbell: View your front porch in crisp 1080p resolution with two-way audio.
- Remote Lock Control: Lock and unlock your door remotely via the Wyze app, with full lock history tracking.
- Motion Event Alerts: Receive notifications for motion events and door lock activity.
- Smart Home Compatibility: Works with Alexa and Google Assistant for voice commands.
- Weather Resistant & Durable: IP65-rated doorbell and robust lock designed for everyday use.
This bundle is ideal for users who want to combine video monitoring with smart lock convenience, enhancing both security and ease of access.
Wyze Video Doorbell Pro: Wireless or Wired with Ultra-Wide View and Quick Install
The Wyze Video Doorbell Pro offers flexibility with both wired and battery-powered options, making installation quick and hassle-free. It boasts a wider ultra-wide viewing angle and smart detection features powered by Cam Plus.
Standout Features:
- Battery or Hardwired Power: Choose the power option that fits your home setup.
- Ultra-Wide Viewing Angle: Capture more of your porch with a broader field of view.
- Smart Detection Alerts: Person, package, vehicle, and pet detection with fast notifications.
- Motion-Activated Security Light: Enhances visibility and deters intruders.
- Two-Way Audio & Custom Chimes: Communicate easily and personalize your doorbell sounds.
- Integration: Works seamlessly with Alexa and Google Assistant.
With a 30-second installation and included chime, this doorbell is perfect for those seeking a versatile, high-tech smart doorbell with facial recognition-ready detection.
Wyze Video Doorbell Pro installed on a modern home entryway
Wyze Duo Cam Battery Doorbell: Dual Cameras for Ultimate Front Porch Security
The Wyze Duo Cam Battery Doorbell is the most advanced battery-powered doorbell from Wyze, featuring dual cameras to monitor both people and packages simultaneously.
Features at a Glance:
- Dual Camera Views: Front camera with 2K resolution and bottom camera with 1080p for package detection.
- AI-Powered Alerts: Real-time AI detections for people, packages, and motion.
- Two-Way Audio & Voice Deterrence: Communicate with visitors and warn off unwanted guests.
- Battery or Hardwired Power: Flexible power options with removable battery pack.
- Local & Cloud Storage: Supports up to 256GB microSD card and cloud storage options.
- Weather Resistant: IP65 rating for all-weather protection.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This doorbell is perfect for users who want comprehensive coverage and advanced AI detection for enhanced security.
Wyze Duo Cam Battery Doorbell installed on a front porch with package delivery
Why Choose Wyze Smart Doorbells with Facial Recognition?
Facial recognition technology in smart doorbells enhances your home security by accurately identifying visitors and reducing false alerts. Wyze smart doorbells combine high-resolution video, AI-powered detection, and seamless smart home integration to provide you with peace of mind and control from anywhere.
With options ranging from wired 2K video doorbells to advanced dual-camera battery-powered models, Wyze offers a smart doorbell for every home and security need.
Summary of Featured Products
Product Name | Power Type | Video Resolution | Special Features | Price Range (USD) |
Wyze Video Doorbell v2 | Wired | 2K (2048x1536) | Local microSD storage, voice deterrence | $44.98 |
The Front Porch Security Bundle | Wired + Lock | 1080p HD | Remote lock control, motion alerts | From $123.99 |
Wyze Video Doorbell Pro | Wired or Battery | HD (1080p+) | Ultra-wide view, motion light, quick install | $99.98 |
Wyze Duo Cam Battery Doorbell | Battery or Wired | Front 2K + Bottom 1080p | Dual cameras, AI detection, removable battery | $89.98 - $109.99 |
Enhance Your Doorbell View with Accessories
For the Wyze Video Doorbell v2, consider the
Wyze Video Doorbell v2 Wedge Kit to adjust the viewing angle perfectly on angled door frames or porches with stairs. This accessory helps eliminate blind spots and maximizes your home security coverage.
Secure your home with the best front door smart doorbells featuring facial recognition and smart home integration. Choose the Wyze model that fits your lifestyle and enjoy peace of mind with advanced video monitoring and intelligent alerts.
What are the main benefits of Wyze smart doorbells with facial recognition?
Wyze smart doorbells with facial recognition enhance home security by accurately identifying visitors, reducing false alerts, and providing high-resolution video monitoring. They also offer intelligent AI-powered detection, seamless smart home integration, and remote access for peace of mind and control from anywhere.Which Wyze smart doorbell models support both wired and wireless installation?
The Wyze Video Doorbell Pro and Wyze Duo Cam Battery Doorbell both support wired and wireless (battery-powered) installation, offering flexibility to fit your home’s setup and installation preferences.What video resolution do Wyze smart doorbells offer?
Wyze smart doorbells offer high-definition video resolutions, including 2K (2048 x 1536) on the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell (front camera), and 1080p HD on the Wyze Video Doorbell Pro, The Front Porch Security Bundle, and the bottom camera of the Duo Cam model.How does the Wyze Duo Cam Battery Doorbell improve front porch security?
The Wyze Duo Cam Battery Doorbell features dual cameras—one for visitors and one for packages—providing comprehensive coverage of your front porch. It uses AI-powered alerts for people, packages, and motion, and supports both local and cloud storage for video recordings.Can Wyze smart doorbells be integrated with Alexa or Google Assistant?
Yes, all featured Wyze smart doorbells are compatible with Alexa and Google Assistant, allowing for voice commands and seamless integration with your existing smart home ecosystem.What is included with the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 comes with a chime controller, wall plate, wedge for angled mounting, and a complete installation kit, making setup straightforward and customizable for your front door.What is the Front Porch Security Bundle and what does it include?
The Front Porch Security Bundle combines a Wyze Video Doorbell, Wyze Lock, and Chime, offering a complete smart access management system. It provides 1080p HD video, two-way audio, remote lock control, motion event alerts, and smart home compatibility.How weather resistant are Wyze smart doorbells?
All Wyze smart doorbells featured are IP65-rated, ensuring they are weather resistant and durable for reliable operation in various outdoor conditions.What storage options are available for Wyze smart doorbells?
Wyze smart doorbells support local storage via microSD cards (up to 256GB on select models) and offer cloud storage options for video recordings, giving you flexibility in how you store and access your footage.How easy is it to install Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro is designed for quick and easy installation, with a 30-second setup whether you choose battery or wired power. It also comes with a chime for added convenience.What accessories are available for Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 Wedge Kit is available to help adjust the viewing angle, making it ideal for angled door frames or porches with stairs. This accessory helps eliminate blind spots and maximizes security coverage.What smart detection features do Wyze doorbells offer?
Wyze doorbells offer advanced smart detection features, including person, package, vehicle, and pet detection, as well as motion-activated security lights and voice deterrence to enhance your home’s security.
