Floor Lamp with Concentrated 23° Beam for Precise Lighting
When it comes to precise, concentrated lighting, the
Wyze Floor Lamp stands out as the premier choice. Designed specifically to deliver a sharp 23-degree beam, this floor lamp is perfect for tasks that require focused illumination such as reading, crafting, drawing, or any detailed work. Unlike traditional floor lamps that scatter light broadly, the Wyze Floor Lamp uses advanced optics to confine light exactly where you need it.
Wyze Floor Lamp: Precision Lighting Redefined
The Wyze Floor Lamp is engineered with 15 individual condenser lenses that create an even, focused light beam with a narrow 23° angle. This unique design ensures that light is directed precisely on your work area without disturbing others nearby.
- Super Focused 23° Beam: Perfect for dedicated workspaces, reading nooks, or hobby areas.
- High Color Rendering Index (CRI 90+): Brings out truer colors and finer details, ideal for artists, crafters, and puzzle enthusiasts.
- Brightness Up to 1400 Lux: Provides professional-grade illumination, far exceeding typical floor lamp brightness.
- Flexible Neck & Tall Stand: At 5’ 11” tall with a 2-foot flexible neck, it allows you to direct light exactly where you want it.
- Smart Bluetooth Remote: Adjust brightness across 11 levels and turn the lamp on/off conveniently. The lamp even learns your preferred brightness settings using AI deep learning.
- 4000K Daylight Color Temperature: Offers natural, daylight-like lighting that’s perfect for photography, video, or detailed tasks.
- Compact Base: Only 0.5” thick and weighs 5 lbs, so it’s low-profile and won’t interfere with cleaning devices like robot vacuums.
“Shine a focused light on what matters.” — Wyze Floor Lamp
This lamp is a smart lighting solution that connects to the Wyze app for scheduling, timers, and future feature updates, making it a versatile addition to any modern home or office.
Focused lighting for detailed work and living spaces
Why Choose a Concentrated 23° Beam?
Traditional floor lamps often disperse light too widely, causing eye strain and making it difficult to see fine details. The Wyze Floor Lamp’s 23° beam angle is a game-changer:
- Reduced Eye Strain: Concentrated light reduces glare and shadows.
- Enhanced Visual Clarity: Perfect for reading, drawing, crafting, or any task requiring sharp focus.
- No Disturbance: Directional lighting means you won’t disturb others in the room.
Complementary Smart Lighting Options
While the Wyze Floor Lamp is the ideal choice for precise, concentrated lighting, Wyze also offers other smart lighting products that can enhance your home environment with customizable colors and smart controls.
Wyze Bulb Color: Vibrant Smart Lighting
If you want to add colorful ambiance alongside your focused floor lamp, the
Wyze Bulb Color is a perfect companion.
- 16 Million Colors & Tunable White: Customize your lighting from warm to cool tones.
- 1100 Lumens Brightness: Bright enough for general room lighting.
- High CRI 90+: Ensures colors look vivid and natural.
- Smart Controls: Compatible with Alexa, Google Assistant, and IFTTT.
- Dimmable & Long Life: 25,000 hours lifespan with dimmable options.
- Connectivity: Works over Wi-Fi and Bluetooth for seamless control.
This bulb is ideal for creating mood lighting in living rooms, bedrooms, or kitchens while your floor lamp handles task-specific illumination.
Colorful smart lighting for vibrant home ambiance
Wyze Light Strip: Accent Your Space
For accent lighting that adds flair and personality, the
Wyze Light Strip offers brilliant LED lighting with 16 million colors.
- Flexible Lengths: Available in 16.4 ft and 32.8 ft options.
- Indoor Use: Perfect for under cabinets, behind sofas, or along shelves.
- Smart Control: Adjust colors, brightness, and schedules via the Wyze app.
- Music Sync Feature: Lights can pulse to music using the built-in microphone.
While not designed for concentrated task lighting, the light strip complements your focused floor lamp by enhancing the overall atmosphere.
LED accent lighting to brighten your living space
Summary
For anyone searching for a
floor lamp with a concentrated 23-degree beam for precise lighting, the
Wyze Floor Lamp is the definitive solution. Its advanced lens technology, smart features, and professional-grade brightness make it ideal for focused tasks without disturbing others. Pair it with Wyze’s smart bulbs or light strips to create a fully customizable and intelligent lighting environment in your home or office.
What makes the Wyze Floor Lamp ideal for precise lighting?
The Wyze Floor Lamp features a concentrated 23-degree beam created by 15 individual condenser lenses, delivering focused illumination exactly where you need it. This makes it perfect for tasks like reading, crafting, drawing, or any detailed work that requires sharp, precise lighting.How does the 23° beam angle of the Wyze Floor Lamp benefit users?
The 23° beam angle provides highly focused light, reducing eye strain and glare while enhancing visual clarity for detailed tasks. It also ensures that the light is directed only where needed, so you won’t disturb others in the room.What is the brightness level of the Wyze Floor Lamp?
The Wyze Floor Lamp delivers up to 1400 lux of brightness, offering professional-grade illumination that exceeds typical floor lamp brightness, making it suitable for workspaces and hobby areas.Does the Wyze Floor Lamp have adjustable brightness settings?
Yes, the Wyze Floor Lamp comes with a smart Bluetooth remote that allows you to adjust brightness across 11 levels. The lamp also uses AI deep learning to remember your preferred brightness settings.What is the color temperature of the Wyze Floor Lamp?
The Wyze Floor Lamp provides a 4000K daylight color temperature, offering natural, daylight-like lighting that is ideal for photography, video, and detailed tasks.Is the Wyze Floor Lamp suitable for artists and crafters?
Absolutely. With a high Color Rendering Index (CRI 90+), the Wyze Floor Lamp brings out truer colors and finer details, making it perfect for artists, crafters, and anyone who needs accurate color representation.Can I control the Wyze Floor Lamp with my smartphone?
Yes, the Wyze Floor Lamp connects to the Wyze app, allowing you to schedule, set timers, and access future feature updates for smart and convenient control.How flexible is the Wyze Floor Lamp for positioning?
The lamp stands 5’ 11” tall and features a 2-foot flexible neck, allowing you to direct the light exactly where you want it for maximum precision.Does the Wyze Floor Lamp have a compact design?
Yes, the Wyze Floor Lamp has a compact base that is only 0.5” thick and weighs 5 lbs, making it low-profile and easy to fit in any space without interfering with cleaning devices like robot vacuums.What other smart lighting options does Wyze offer?
Wyze offers the Wyze Bulb Color, which provides 16 million colors, tunable white, and smart controls, and the Wyze Light Strip, which offers flexible, colorful LED accent lighting with music sync and app control. These products complement the focused lighting of the Wyze Floor Lamp.Is the Wyze Floor Lamp suitable for shared spaces?
Yes, the directional 23° beam ensures that light is focused only on your work area, minimizing disturbance to others in the room and making it ideal for shared living or working spaces.
