To help you compare the field of view for the Wyze Cam v3, here's a detailed comparison of its features:
Feature | Wyze Cam v3 |
Diagonal Field of View | 121° |
Horizontal Field of View | Not specified |
Vertical Field of View | 180° vertical range |
Video Resolution | 1080p |
Night Vision | Color Night Vision |
Weather Resistance | IP65 |
Audio | Two-way talk with ECM mic |
Connectivity | 2.4GHz WiFi |
Storage | microSD card required, cloud storage with subscription |
Operating Temperature | -5°F to 113°F (-20°C to 45°C) |
The Wyze Cam v3 is designed to provide a wide field of view, making it ideal for both indoor and outdoor monitoring. Its color night vision and IP65 weather resistance ensure reliable performance in various conditions. Additionally, it supports two-way audio and integrates with Alexa and Google Assistant for enhanced convenience.
