Enhance Your Wyze Cam Setup in Detached Garages with a 20ft USB Extension Cable
If you're looking to extend the reach of your Wyze Cam installed in a detached garage, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here are some key features of this product:
  • Length: 20 feet, providing ample reach for installations in larger spaces.
  • Compatibility: Works with a variety of Wyze Cam models, including Wyze Cam v2, v3, v4, and more.
  • Weather Rating: IP67, ensuring durability and performance in various weather conditions.
  • Connector Type: USB Type A Male to Female, making it easy to connect and extend your camera's power supply.
This extension cable will help you maintain a reliable connection to your Wyze Cam, even in more challenging installation environments like a detached garage.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What is the weather rating of the Wyze Cam USB Extension Cable?Do you have any ongoing sales or discounts available?
