For those looking to position their Wyze Cam away from curious pets, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here’s why this product is ideal for your needs:
- Extended Reach: With a length of 20ft, this USB extension cable allows you to place your Wyze Cam in a more secure or discreet location, away from pets or other potential disturbances.
- Compatibility: This cable is compatible with a wide range of Wyze Cameras, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistant: Featuring an IP67 weather rating, this cable is suitable for both indoor and outdoor use, ensuring durability in various environments.
- Easy Installation: The cable is designed for easy installation, allowing you to quickly set up your camera in the desired location.
This extension cable provides the flexibility and convenience needed to keep your Wyze Cam safe and functional, even in pet-friendly homes.
