Extended Power Cord and Outdoor Power Adapter for Wyze Cam v3 and v4
When monitoring a large backyard or expansive outdoor area, having a reliable power source and extended cabling for your Wyze Cam is essential. Wyze offers solutions tailored to keep your cameras powered continuously, ensuring uninterrupted security coverage. Whether you own the Wyze Cam v3 or the latest Wyze Cam v4, the right power accessories can make all the difference in maximizing your outdoor surveillance.
Wyze Cam v4 Outdoor Bundle: Ultimate Outdoor Security with Power Included
The
Wyze Cam v4 Outdoor Bundle is the perfect all-in-one solution for outdoor monitoring with extended power needs in mind. This bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB microSD card, providing everything you need for continuous, high-quality surveillance.
Key Features:
- 2.5K QHD Resolution: Capture crystal-clear video with Quad HD clarity, ensuring every detail in your backyard is visible.
- Enhanced Color Night Vision: See vibrant colors even in low light, thanks to advanced hardware that outperforms traditional night vision.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders and illuminating your yard.
- 24/7 Local Recording: Continuous recording to the included 128GB microSD card means you never miss a moment.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection over greater distances, ideal for large outdoor spaces.
- Compatibility: Works seamlessly with Alexa and Google Assistant for voice control and smart home integration.
- Weather Resistant: Designed to withstand rain, snow, and shine, rated for outdoor durability.
Power and Connectivity:
- The included Wyze Outdoor Power Adapter ensures your camera stays powered without interruption.
- The power adapter is designed specifically for outdoor use, providing a weatherproof connection.
- The bundle’s cable length and power setup support flexible placement, perfect for large backyards.
"The clearest Wyze Cam ever made, bundled with outdoor power and storage for nonstop security."
Wyze Cam v4 Outdoor Bundle in action, securing a large backyard with night vision and spotlight.
Wyze Cam v4: Powerful Wired Camera for Large Outdoor Areas
If you already own a Wyze Cam v4 or want to customize your setup, the
Wyze Cam v4 itself is a top-tier wired security camera designed for both indoor and outdoor use (with the outdoor power adapter).
Highlights:
- 2.5K QHD Video Quality: High-resolution video with Wide Dynamic Range (WDR) for vibrant, detailed images.
- IP65 Weather Resistance: Reliable performance in harsh weather conditions, from freezing cold to hot summers.
- Enhanced Two-Way Talk & Siren: Communicate clearly or deter intruders with a loud 99dB siren.
- Motion and Sound Detection: Receive instant alerts on your phone when motion or sound is detected.
- Motion Detection Zones: Customize which areas to monitor, reducing false alarms.
- Bluetooth Setup & Magnetic Mount: Easy installation with no screws required, plus flexible mounting options.
- Supports MicroSD Cards up to 512GB: For extensive local storage without subscription fees.
Power Requirements:
- The Wyze Cam v4 requires a Wyze Outdoor Power Adapter (sold separately) for outdoor use.
- The camera comes with a 6-foot flat micro USB to USB-A cable, but for larger backyards, Wyze offers extension cables to increase reach.
"Ideal for large outdoor spaces, the Wyze Cam v4 combines high resolution, weather resistance, and smart features."
Wyze Cam v4 Home Security Bundle: Comprehensive Protection with Power and Storage
For those seeking a complete security package, the
Wyze Cam v4 Home Security Bundle offers multiple cameras with power adapters and microSD storage included.
Bundle Benefits:
- Includes multiple Wyze Cam v4 units with 128GB microSD cards.
- Each camera features motion-activated spotlights and sirens.
- Supports Wi-Fi 6 for reliable connectivity across large properties.
- IP65 weather resistance ensures cameras withstand outdoor elements.
- Multiple mounting options for versatile placement.
This bundle is perfect for monitoring large backyards with several cameras, all powered continuously via included adapters.
Wyze Outdoor Power Adapter and Extended Power Cords
To monitor a large backyard effectively, power accessibility is crucial. Wyze provides:
- Wyze Outdoor Power Adapter: Specifically designed for outdoor use with weatherproof casing, compatible with Wyze Cam v3 and v4.
- Extension Cables: Wyze offers extension cables (such as 20ft extension cables) to increase the reach of your camera’s power supply, ideal for sprawling outdoor areas.
Using these accessories ensures your Wyze Cam stays powered without interruption, even when placed far from your home’s power outlets.
Wyze Cam v3 Spotlight Kit: Enhance Your Existing Setup
If you have a
Wyze Cam v3 and want to improve its outdoor lighting, the
Wyze Cam v3 Spotlight Kit is a great accessory.
Features:
- Motion-Activated Spotlight: 70 lumens of bright light with a 130-degree beam angle.
- IP65 Rated: Weatherproof for outdoor use.
- Easy Connection: Powered via micro USB, compatible with Wyze Cam v3.
- Improves Night Vision: Adds color illumination to your existing camera’s black-and-white night vision.
This kit pairs well with extended power cords and the outdoor power adapter to keep your Wyze Cam v3 powered and well-lit for large backyard monitoring.
Summary: Best Power Solutions for Wyze Outdoor Cameras
Product | Power Solution Included | Ideal For | Key Benefit |
Wyze Cam v4 Outdoor Bundle | Yes (Outdoor Power Adapter + 128GB microSD) | Large outdoor areas | Complete outdoor-ready package |
Wyze Cam v4 | No (Power adapter sold separately) | Custom setups, large backyards | High-res wired camera with Wi-Fi 6 |
Wyze Cam v4 Home Security Bundle | Yes (Power adapters + 128GB microSD) | Multi-camera large properties | Multiple cameras with power & storage |
Wyze Cam v3 Spotlight Kit | No (Accessory spotlight only) | Existing Wyze Cam v3 users | Enhanced night lighting |
Wyze Cam v4 mounted outdoors, ideal for large backyard monitoring with extended power solutions.
Conclusion
For monitoring a large backyard with Wyze cameras, the
Wyze Cam v4 Outdoor Bundle is the most convenient and powerful option, including the essential outdoor power adapter and ample local storage. If you already own a Wyze Cam v4, pairing it with the
Wyze Outdoor Power Adapter and extension cables will ensure continuous power supply across your property. For Wyze Cam v3 users, the
Spotlight Kit combined with the outdoor power adapter and extended cords enhances night vision and coverage.
Investing in these power accessories guarantees your Wyze cameras stay online and effective, providing peace of mind and comprehensive security for your large outdoor spaces.
What is the Wyze Cam v4 Outdoor Bundle and what does it include?
The Wyze Cam v4 Outdoor Bundle is an all-in-one outdoor security solution that includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB microSD card. This bundle provides everything you need for continuous, high-quality surveillance in large backyards or outdoor areas.Is the Wyze Outdoor Power Adapter weatherproof?
Yes, the Wyze Outdoor Power Adapter is specifically designed for outdoor use with a weatherproof casing, making it ideal for powering Wyze Cam v3 and v4 cameras in all weather conditions.Can I use extension cables with my Wyze Cam for large outdoor areas?
Yes, Wyze offers extension cables, such as 20ft extension cords, to increase the reach of your camera’s power supply. These are perfect for placing your Wyze Cam v3 or v4 in large backyards or areas far from power outlets.What are the benefits of the Wyze Cam v4 for outdoor security?
The Wyze Cam v4 offers 2.5K QHD video quality, enhanced color night vision, motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, and IP65 weather resistance. It is ideal for large outdoor spaces and provides reliable, high-resolution surveillance.Do I need a special power adapter to use Wyze Cam v4 outdoors?
Yes, to use the Wyze Cam v4 outdoors, you need the Wyze Outdoor Power Adapter, which is sold separately unless you purchase a bundle that includes it. This adapter ensures safe and continuous power in outdoor environments.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units, each with a 128GB microSD card and a Wyze Outdoor Power Adapter. This bundle is designed for comprehensive protection of large properties with multiple cameras.Is the Wyze Cam v3 compatible with outdoor power solutions?
Yes, the Wyze Cam v3 is compatible with the Wyze Outdoor Power Adapter and extension cables, allowing for reliable outdoor installation and continuous power supply.How does the Wyze Cam v3 Spotlight Kit enhance outdoor security?
The Wyze Cam v3 Spotlight Kit adds a motion-activated, 70-lumen spotlight with a 130-degree beam angle to your existing Wyze Cam v3. It improves night vision by providing color illumination and is weatherproof for outdoor use.Can I use microSD cards with Wyze Cam v4 for local recording?
Yes, the Wyze Cam v4 supports microSD cards up to 512GB for extensive local storage, allowing for 24/7 continuous recording without subscription fees.Which Wyze camera bundle is best for monitoring a large backyard?
The Wyze Cam v4 Outdoor Bundle is the most convenient and powerful option for large backyard monitoring, as it includes the camera, outdoor power adapter, and ample local storage for nonstop security coverage.
