Enhance Your Home with Wyze Sense Entry Sensor: Real-Time Alerts & Easy Integration
The Wyze Sense Entry Sensor is an excellent choice for those looking to enhance their home monitoring system. Here are some key features that make it a great addition to your security setup:
  • Open/Close Detection : The sensor is designed to detect when doors or windows are opened or closed, providing you with real-time alerts.
  • Compatibility : It works seamlessly with Wyze Sense v2 or Wyze Home Monitoring, ensuring easy integration into your existing system.
This sensor is part of our top sellers and is available for purchase in a convenient 3-pack. Enhance your home security with the Wyze Sense Entry Sensor today!
Wide Detection Zone
Offers a 120-degree field of vision within 25 feet, making it ideal for various installation locations.
Long Battery Life
Enjoy up to 18 months of battery life, reducing the need for frequent replacements.
Easy Integration
Works seamlessly with Wyze Sense v2 or Wyze Home Monitoring, ensuring a streamlined setup without extra hassle.
Why do some people prefer having sensors as part of their home security system?
  • They provide real-time alerts that help homeowners react immediately to unexpected events.
  • Enhanced monitoring of critical entry points increases overall security.
  • Easy integration with smart home systems streamlines automation and control.
  • Long battery life and low maintenance offer a convenient, reliable solution.
  • Privacy: Sensors do not capture video, preserving your privacy while keeping your home secure.
Wyze HMS Group
Sensor Comparison
Feature Wyze Sense Climate Sensor Wyze Sense Motion Sensor Wyze Sense Leak Sensor
Price $41.98 $20.98 $55.98
Pack 3 Pack 1 Pack 3 Sensors and 1 Probe
Use Case Monitor temperature & humidity Detect motion Detect water leaks
Requirement Requires Wyze Sense Hub
Buy Now Buy Now Buy Now Buy Now
Note: Only one Wyze Sense Hub is required per household to operate all sensors. Ensure your Wyze Sense Hub is installed to unlock the full potential of your home monitoring system.
Can you tell me more about the compatibility of the Wyze Sense Entry Sensor with other Wyze products? What is the detection range of the Wyze Sense Entry Sensor? Is there a warranty for the Wyze Sense Entry Sensor?
Need help finding the perfect Wyze Cam? Check out our Product Finder ✨
Shop with AI powered by Big Sur AI
