How to Remove Wyze Cam Window Mount with Minimal Residue: Tips for v1/v2 Models
To ensure minimal residue when removing a Wyze Cam mount from a window, it's important to use the right mounting method. For Wyze Cam v1/v2, the mounting kit includes a metal plate with strong adhesive tape, which is designed for a permanent fixture. If you prefer a less permanent solution, consider using the magnetic base on existing steel surfaces or the screw option provided in the mounting kit. This way, you can avoid adhesive residue on your window. Wyze Cam v1/v2 Mounting Kit: Includes a metal mounting plate with adhesive for permanent fixtures, offers a screw option for less permanent mounting, and is compatible with Wyze Cam v1/v2.
What are the different mounting options available for the Wyze Cam Pan?Can you explain how to set up the Wyze Cam Pan v2?What are the tech specs for the Wyze Cam Pan v2?
