Energy Saving Outdoor Power Converter for Wyze Home Security Devices
When it comes to powering your Wyze home security devices outdoors, having a reliable, energy-efficient, and weather-resistant power adapter is essential. The
Wyze Outdoor Power Adapter is specifically designed to keep your Wyze cameras running smoothly in any weather condition, ensuring continuous security coverage without interruption.
Wyze Outdoor Power Adapter: Durable & Energy Efficient
Weather-Resistant Design for All Seasons
The Wyze Outdoor Power Adapter boasts an
IP67 weather resistance rating, making it fully capable of withstanding rain, snow, and extreme temperatures ranging from -30°C to 50°C (-22°F to 122°F). This means you can confidently install your Wyze cameras outdoors without worrying about power interruptions caused by harsh weather.
Energy-Saving Specifications
- Input Power: 100V-240V AC
- Output Power: 5V 2A DC
- Cable Length: 12.5 ft (3.8 m) total, with 3.9 ft AC cable and 8.5 ft DC cable
- Connector: Micro USB to camera, 2-pin flat US wall plug
- Operating Temperature: -22°F to 122°F (-30°C to 50°C)
- Certifications: FCC and UL certified for safety and reliability
Compatibility & Accessories
This adapter is compatible with a range of Wyze cameras including Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with additional USB-C adapter). It comes with useful accessories such as wire clips, screws, anchors, and weatherproof L-shaped adapters to ensure a neat and secure installation.
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter is your go-to solution for powering Wyze cameras outdoors efficiently and safely.
Experience reliable outdoor security with Wyze Cam Pan v3 powered by the Wyze Outdoor Power Adapter.
Wyze Cam Pan v3: Perfect Partner for Outdoor Power Adapter
360° Pan and 180° Tilt Coverage
The Wyze Cam Pan v3 offers comprehensive surveillance with its ability to pan 360° horizontally and tilt 180° vertically. This wide coverage ensures no blind spots around your property.
Robust Outdoor Features
- IP65 Weather Resistance: Suitable for outdoor use when paired with the Wyze Outdoor Power Adapter
- 1080p Full HD Video: Crisp, clear video quality day and night
- Color Night Vision: Enhanced visibility in low light conditions
- Two-Way Audio: Built-in microphone and speaker for real-time communication
- Motion Tracking: Automatically follows moving objects for better monitoring
Energy & Connectivity
Powered by a 5V/2A adapter, the Pan v3 supports 2.4 GHz Wi-Fi connectivity and integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
For safe and continuous outdoor operation, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter, making this duo an unbeatable combination for home security.
Bird Feeder Plug-in Cam v4 Bundle: Outdoor Power Meets Nature Watching
All-in-One Outdoor Bundle
This bundle includes the Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter, making it an excellent choice for bird enthusiasts who want to monitor wildlife while securing their property.
Features of the Bundle
- Weather-Resistant for All Seasons: Durable design for year-round use
- Easy Installation: Multiple mounting options including wall, tree, pole, and suction cup
- Compatible with Wyze Solar Panel: For additional energy-saving options
- Macro Lens Adapter Included: Capture detailed close-ups of birds visiting your feeder
Wyze Cam v4 Highlights
- 1080p HD video with color night vision
- Motion detection and real-time alerts
- Two-way audio for interaction
This bundle combines outdoor power efficiency with the joy of birdwatching, powered reliably by the Wyze Outdoor Power Adapter.
Why Choose Wyze Outdoor Power Solutions?
- Energy Efficient: Low power consumption with 5V/2A output ensures your devices run efficiently without wasting electricity.
- Weatherproof: IP67 rating means your devices stay powered through rain, snow, and extreme temperatures.
- Versatile Compatibility: Supports multiple Wyze camera models and accessories for flexible setups.
- Complete Installation Kit: Comes with all necessary mounting hardware and adapters for hassle-free setup.
Investing in the Wyze Outdoor Power Adapter means securing your home with uninterrupted power, no matter the weather, while saving energy.
Summary
For anyone looking to power their Wyze home security devices outdoors with an energy-saving, weather-resistant solution, the
Wyze Outdoor Power Adapter is the ideal choice. Paired with cameras like the
Wyze Cam Pan v3 or bundled with the
Bird Feeder Plug-in Cam v4 Bundle, it ensures your outdoor security and monitoring needs are met with reliability and efficiency.
What is the Wyze Outdoor Power Adapter and what devices is it compatible with?
The Wyze Outdoor Power Adapter is a weather-resistant, energy-efficient power supply designed specifically for Wyze home security devices. It is compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with an additional USB-C adapter).Is the Wyze Outdoor Power Adapter weatherproof?
Yes, the Wyze Outdoor Power Adapter has an IP67 weather resistance rating, making it fully capable of withstanding rain, snow, and extreme temperatures from -22°F to 122°F (-30°C to 50°C).How energy efficient is the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is highly energy efficient, featuring a 5V/2A DC output that ensures your Wyze devices run efficiently without wasting electricity.What is included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) cable, wire clips, screws, anchors, and weatherproof L-shaped adapters for a secure and neat installation.Can I use the Wyze Outdoor Power Adapter with the Wyze Cam Pan v3 outdoors?
Yes, the Wyze Cam Pan v3 is designed for outdoor use when paired with the Wyze Outdoor Power Adapter, providing 360° pan and 180° tilt coverage with robust weather resistance.What are the key features of the Wyze Cam Pan v3 for outdoor security?
The Wyze Cam Pan v3 offers 360° pan and 180° tilt, IP65 weather resistance, 1080p Full HD video, color night vision, two-way audio, and motion tracking, making it ideal for comprehensive outdoor surveillance.What is included in the Bird Feeder Plug-in Cam v4 Bundle?
The Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter. It also features a macro lens adapter and offers multiple mounting options for easy installation.Is the Wyze Outdoor Power Adapter certified for safety?
Yes, the Wyze Outdoor Power Adapter is FCC and UL certified, ensuring safety and reliability for outdoor use.Can the Wyze Outdoor Power Adapter be used with a solar panel?
Yes, the Wyze Outdoor Power Adapter is compatible with the Wyze Solar Panel, providing additional energy-saving options for your outdoor security setup.Why should I choose the Wyze Outdoor Power Adapter for my home security devices?
The Wyze Outdoor Power Adapter offers energy efficiency, weatherproof durability, versatile compatibility with multiple Wyze cameras, and comes with a complete installation kit, making it the ideal solution for uninterrupted outdoor security.
