Discover Easy Wyze Window Camera Mounts for Short-Term Apartment Renters
For short-term apartment renters looking for an easy window camera mount, we recommend the following products:
  • Wyze Window Mount: This accessory is perfect for upgrading your exterior security by attaching a Wyze Cam v3, v3 Pro, v4, or the Wyze Cam OG series to your window. It allows you to mount your camera on a glass surface, providing a clear view free of glare or reflection. The v2 style is currently available and compatible with a wide range of Wyze cameras.
  • Wyze Cam Mounting Kit: This kit is designed for Wyze Cam v2, v3, and v3 Pro. It includes a mounting bracket, adhesive, and a longer Micro USB cable, making it a versatile option for renters who need a temporary yet secure mounting solution.
  • Wyze Cam OG Stack Kit: If you have Wyze Cam OG or OG Telephoto cameras, this stack kit allows you to power and stack-ably mount two cameras on top of each other. It includes a USB Cable Splitter, a Power Brick, and a Stack Mount, providing flexibility in camera placement.
These options offer easy installation and removal, making them ideal for renters who need temporary solutions without causing damage to their living space.
FeatureWyze Window MountWyze Cam Mounting KitWyze Cam OG Stack Kit
CompatibilityWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cam v2, v3, v3 ProWyze Cam OG, Wyze Cam OG Telephoto
Price$4.99$5.99$9.99
Stock AvailabilityAvailableAvailableAvailable
Included AccessoriesNoneMounting bracket, adhesive, longer Micro USB cableUSB Cable Splitter, Power Brick, Stack Mount
Installation SurfaceGlass surfaceVarious surfacesStackable mount for two cameras
Special FeaturesReduces glare, clear view free of reflectionIncludes a spare mounting plateAllows stacking and powering two cameras
Ideal ForEasy window mounting for rentersTemporary yet secure mounting solutionFlexible camera placement for Wyze Cam OG series
What are the installation steps for the Wyze Window Mount?Can the Wyze Window Mount be used with other camera models?Is the Wyze Cam Mounting Kit easy to remove when I move out?
