Effortlessly Extend Your Wyze Outdoor Camera's Battery Life with the Wyze Solar Panel
To maintain your outdoor camera operation effortlessly, consider using the Wyze Battery Cam Solar Panel. This solar panel is designed to extend the battery life of your Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2, allowing you to record for longer periods without needing to recharge manually. The panel is weather-resistant and can be mounted anywhere, making it ideal for outdoor use. It features an easy 360° mount and a 13-foot power cable, ensuring flexibility in installation. For optimal performance, mount the solar panel facing south and tilted upward at a 30º angle to capture maximum sunlight.
Feature | Wyze Battery Cam Solar Panel | Wyze Battery Cam Pro | Wyze Cam Outdoor v1 |
Price | $24.99 | $89.98 (1 Pack) | $51.99 (Add-On Camera) |
Weather Resistance | IP65 | IP65 | IP65 |
Power Source | Solar | Removable, Rechargeable Battery Packs | 2 x 2500 mAh wire-free battery |
Mounting Options | 360° Mount | 1/4” - 20 standard | Magnetic, Screw, 3rd party 1/4" - 20 mount |
Dimensions | 173 mm x 120 mm x 17 mm | 2.5 x 1.8 x 3.5 inches | 2.3 inch x 2.3 inch x 2.8 inch |
Additional Features | 13-foot Power Cable | Integrated Spotlight & Siren | Supports up to 256GB microSD |
How does the Wyze Battery Cam Solar Panel work to extend battery life?What are the installation requirements for the Wyze Battery Cam Solar Panel?Can the solar panel be used in all weather conditions?
