For those looking to discreetly extend the reach of their Wyze Cam setup, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here’s why it stands out:
- Extended Reach: With a length of 20 feet, this cable allows you to position your Wyze Cam in the perfect spot without worrying about proximity to a power source.
- Compatibility: It works seamlessly with a variety of Wyze Cam models, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistant: The cable is designed with an IP67 weather rating, making it suitable for both indoor and outdoor use.
- Easy Installation: Its simple design ensures that setting up your camera is hassle-free, even when running the cable under carpet edges for a clean look.
Additionally, if you need to mount your Wyze Cam securely, consider the Wyze Cam Mounting Kit. It includes a mounting bracket, adhesive, and a longer Micro USB cable, providing a comprehensive solution for setting up your camera in the desired location.
