Wyze Cordless Vacuum S: The Ultimate Cordless Vacuum for Long-Haired Pets
If you're searching for a
cordless vacuum with a tangle-free brush roll designed specifically for homes with long-haired pets, the
Wyze Cordless Vacuum S is your perfect match. Engineered to tackle pet hair effortlessly, this vacuum combines powerful suction, lightweight design, and smart features to keep your living space spotless.
Powerful Suction for Deep Cleaning
The Wyze Cordless Vacuum S boasts an impressive
20,000 Pa suction power in Turbo Mode, ensuring even the most stubborn pet hair and debris are removed from carpets, hardwood floors, and upholstery. With three suction modes—ECO (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa)—you can customize cleaning power based on your needs, balancing performance and battery life.
100 AW suction power
- Two motors for enhanced cleaning efficiency
- 6 daylight-bright LED lights on the brush head to illuminate hidden dirt and pet hair
This vacuum is designed to handle the challenges of long-haired pets without the frustration of tangled brush rolls, making pet hair cleanup easier than ever.
Lightweight and Ergonomic Design
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is incredibly easy to maneuver around furniture and tight spaces. Its compact dimensions (12.4 x 4.5 x 8.7 inches for the main unit) and ergonomic design reduce fatigue during extended cleaning sessions.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." — Wyze
Long-Lasting Battery Life
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the Wyze Cordless Vacuum S offers up to
40 minutes of runtime in ECO mode, perfect for thorough cleaning without interruptions. The battery is interchangeable, allowing you to swap in a fresh pack for extended cleaning sessions.
- Charging time: 4-6 hours to full charge
- Rated voltage: DC 21.6 V
- Rated power output: 300 W
For those who need extra power on the go, the
Wyze Cordless Vacuum S - Battery Pack accessory is available to double your cleaning time.
Advanced Filtration and Attachments
The vacuum features a
3-stage filtration system including a HEPA filter, which traps fine dust, allergens, and pet dander, improving your home's air quality. The dust cup holds up to
0.7 liters, minimizing frequent emptying.
Included attachments enhance versatility:
- Crevice Tool for tight corners
- Floor Brush for hard floors and carpets
- Dust Cap and HEPA Filter for maintenance
Additional accessories like the
Mini Motorized Brush Head are perfect for cleaning car seats and sofas, while the
Foldable Vacuum Tube helps you reach awkward spaces without bending.
Quiet and Convenient Operation
Operating at a noise level of
65 dBA in Turbo Mode, the Wyze Cordless Vacuum S is quieter than many traditional vacuums, making it less stressful for pets and family members.
Its
LED screen provides real-time information on battery life and suction mode, keeping you informed during cleaning.
Enhance Your Wyze Vacuum Experience with Accessories
To maximize the performance and convenience of your Wyze Cordless Vacuum S, consider these compatible accessories:
- Battery Pack ($59.99): Extend your cleaning sessions with an extra battery designed specifically for the Wyze Cordless Vacuum S.
- Charger ($4.99): Replacement charger to keep your vacuum powered up.
- Foldable Vacuum Tube ($15.99): Flexible tube attachment to reach difficult areas effortlessly.
- HEPA Filter (2 Pack) ($15.99): Replace filters regularly to maintain optimal filtration.
- Mini Motorized Brush Head ($29.99): Ideal for cleaning upholstery, car interiors, and sofas.
Why Choose Wyze Cordless Vacuum S for Pet Owners?
The Wyze Cordless Vacuum S is engineered with pet owners in mind, offering a tangle-free brush roll and powerful suction to handle long pet hair without clogging or loss of performance. Its lightweight design and long battery life make it a practical choice for daily cleaning, while the advanced filtration system ensures a healthier home environment.
Effortless pet hair cleanup with Wyze Cordless Vacuum S
Lightweight and powerful vacuum for pet-friendly homes
Perfect for hardwood floors and pet hair removal
Product Summary
Feature | Specification |
Suction Power | Up to 20,000 Pa (Turbo Mode) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 40 min runtime (ECO) |
Filtration | 3-stage with HEPA filter |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Attachments Included | Crevice Tool, Floor Brush, HEPA Filter, Dust Cap |
Accessories Available | Battery Pack, Charger, Foldable Tube, Mini Brush Head, HEPA Filters |
Choose the
Wyze Cordless Vacuum S for a powerful, lightweight, and pet-friendly cleaning solution that keeps your home fresh and free of long pet hair tangles.
What makes the Wyze Cordless Vacuum S ideal for homes with long-haired pets?
The Wyze Cordless Vacuum S features a tangle-free brush roll and powerful suction, specifically designed to handle long pet hair without clogging or loss of performance. Its advanced filtration system and included attachments make it perfect for pet-friendly homes.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 20,000 Pa suction power in Turbo Mode and 100 AW suction power, ensuring deep cleaning of carpets, hardwood floors, and upholstery. It has three adjustable suction modes: ECO (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa).How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode with its 6-cell lithium-ion battery. The battery is interchangeable, allowing you to swap in a fresh pack for extended cleaning sessions.Is the Wyze Cordless Vacuum S lightweight and easy to use?
Yes, the Wyze Cordless Vacuum S weighs only 2.8 lbs for the main unit and 4.9 lbs when fully assembled. Its ergonomic and compact design makes it easy to maneuver around furniture and tight spaces, reducing fatigue during cleaning.What filtration system does the Wyze Cordless Vacuum S use?
The vacuum uses a 3-stage filtration system, including a HEPA filter that traps fine dust, allergens, and pet dander, improving your home's air quality.What attachments and accessories are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a Crevice Tool, Floor Brush, Dust Cap, and HEPA Filter. Additional accessories like the Mini Motorized Brush Head, Foldable Vacuum Tube, extra Battery Pack, and replacement HEPA Filters are also available for purchase.How quiet is the Wyze Cordless Vacuum S during operation?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it quieter than many traditional vacuums and less stressful for pets and family members.How large is the dust cup on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a 0.7-liter dust cup, which minimizes the need for frequent emptying during cleaning sessions.Does the Wyze Cordless Vacuum S have a display for battery and mode information?
Yes, the vacuum is equipped with an LED screen that provides real-time information on battery life and suction mode, keeping you informed while cleaning.What are the available accessories for the Wyze Cordless Vacuum S and their prices?
Available accessories include a Battery Pack ($59.99), Charger ($4.99), Foldable Vacuum Tube ($15.99), HEPA Filter 2-Pack ($15.99), and Mini Motorized Brush Head ($29.99).How long does it take to fully charge the Wyze Cordless Vacuum S?
It takes approximately 4-6 hours to fully charge the Wyze Cordless Vacuum S.Is the Wyze Cordless Vacuum S suitable for cleaning hardwood floors and carpets?
Yes, the Wyze Cordless Vacuum S is designed to clean both hardwood floors and carpets effectively, thanks to its powerful suction and versatile attachments.
