Cordless Vacuum with Interchangeable Battery and Fast Recharge Technology
Discover the ultimate cleaning freedom with the
Wyze Cordless Vacuum S, designed to deliver powerful suction, lightweight handling, and the convenience of interchangeable batteries. Perfect for busy homes, pet owners, and anyone who values efficiency and ease, this vacuum combines advanced technology with user-friendly features to keep your space spotless.
Wyze Cordless Vacuum S: Powerful, Lightweight, and Independent
Industrial-Level Suction Power
Experience unmatched cleaning performance with
20,000 Pa suction power driven by not one, but
two powerful digital motors. This dual-motor system ensures deep cleaning on all surfaces, from carpets to hardwood floors, capturing dust, pet hair, and debris with ease.
Lightweight and Ergonomic Design
Weighing just
2.8 pounds—lighter than a fluffy corgi puppy—this vacuum is effortless to maneuver around furniture and up stairs. Its feather-light design reduces fatigue, making extended cleaning sessions comfortable.
Interchangeable Lithium-Ion Battery
Say goodbye to interruptions with a
40-minute fade-free runtime powered by a removable, rechargeable lithium-ion battery. When the battery runs low, simply swap it out for a fully charged one (sold separately) and keep cleaning without delay.
The Wyze Cordless Vacuum S supports quick charging, so your battery is ready to go when you are. This means less downtime and more cleaning efficiency.
Versatile Cleaning Modes
Choose the right suction power for every task with three adjustable speeds:
- Eco: 6,000 Pa for light cleaning
- Medium: 9,000 Pa for everyday messes
- Turbo: 20,000 Pa for deep cleaning
Enhanced Visibility and Filtration
Equipped with
6 daylight-bright LED lights on the brush head, it illuminates hidden dust under furniture and in dark corners. The
3-stage filtration system includes a vacuum cyclone, metal screen, and HEPA filter that traps 95% of particles as small as 0.3 microns, ensuring cleaner air in your home.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Lightweight and pet-friendly cleaning
Essential Accessories for Extended Use and Convenience
Wyze Cordless Vacuum S - Battery Pack
Need extra juice? The
Wyze Cordless Vacuum S Battery Pack is designed specifically for the vacuum, allowing you to double your cleaning time by swapping batteries. Perfect for larger homes or deep cleaning sessions.
Wyze Cordless Vacuum S - Charger
Keep your vacuum powered up with the official
replacement charger. Fast and reliable, it ensures your battery is ready for action whenever you need it.
Why Choose Wyze Cordless Vacuum S?
- Interchangeable battery system for uninterrupted cleaning
- Fast recharge technology minimizes downtime
- Dual motors for superior suction power
- Lightweight design for easy handling
- LED lights to reveal hidden dust
- HEPA filtration for healthier air quality
- Compatible with a range of accessories to customize your cleaning experience
Perfect for hardwood floors and everyday messes
Conclusion
The
Wyze Cordless Vacuum S stands out as a top choice for anyone seeking a cordless vacuum with an interchangeable battery and fast recharge technology. Its powerful suction, lightweight design, and smart features make cleaning effortless and efficient. Enhance your cleaning routine with the additional battery pack and charger to keep your home spotless without interruption.
What makes the Wyze Cordless Vacuum S different from other cordless vacuums?
The Wyze Cordless Vacuum S stands out with its powerful dual-motor system delivering 20,000 Pa suction, lightweight 2.8-pound design, interchangeable lithium-ion battery for uninterrupted cleaning, and fast recharge technology. It also features LED lights for better visibility and a 3-stage HEPA filtration system for cleaner air.How long does the Wyze Cordless Vacuum S battery last on a single charge?
The Wyze Cordless Vacuum S offers up to 40 minutes of fade-free runtime on a single charge, allowing you to clean large areas without frequent recharging.Can I swap out the battery on the Wyze Cordless Vacuum S?
Yes, the Wyze Cordless Vacuum S features an interchangeable lithium-ion battery. You can easily swap out a depleted battery for a fully charged one (sold separately) to extend your cleaning time.How fast does the Wyze Cordless Vacuum S battery recharge?
Thanks to its fast recharge technology, the Wyze Cordless Vacuum S battery recharges quickly, minimizing downtime and ensuring your vacuum is ready when you need it.What types of surfaces can the Wyze Cordless Vacuum S clean?
The Wyze Cordless Vacuum S is designed for versatile cleaning on all surfaces, including carpets, hardwood floors, and tiles. Its powerful suction and adjustable cleaning modes make it effective for various messes.What are the different cleaning modes available on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers three cleaning modes: Eco (6,000 Pa) for light cleaning, Medium (9,000 Pa) for everyday messes, and Turbo (20,000 Pa) for deep cleaning.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter that traps 95% of particles as small as 0.3 microns, helping to improve air quality in your home.Are there any accessories available for the Wyze Cordless Vacuum S?
Yes, essential accessories such as the Wyze Cordless Vacuum S Battery Pack and the official replacement charger are available. These accessories help extend your cleaning time and keep your vacuum powered up.How much does the Wyze Cordless Vacuum S weigh?
The Wyze Cordless Vacuum S weighs just 2.8 pounds, making it extremely lightweight and easy to maneuver around your home.Does the Wyze Cordless Vacuum S have LED lights for cleaning?
Yes, the Wyze Cordless Vacuum S is equipped with 6 daylight-bright LED lights on the brush head, illuminating hidden dust and debris under furniture and in dark corners.
