For comprehensive long-term video monitoring with your Wyze Cam, we recommend using the Wyze MicroSD Card. Here’s why it’s an excellent choice:
- Continuous Recording: Unlock continuous recording and time-lapse features for your Wyze Cams with this memory card.
- High Capacity Options: Available in 256GB, 128GB, and 32GB, allowing you to choose the storage capacity that best suits your needs.
- Class 10 and UHS-3 (U3) Speed: Ensures fast read and write speeds, which are essential for high-quality video recording.
- Local Storage: Provides a cost-effective solution for storing video footage without the need for a subscription.
Additionally, if you're interested in enhancing your home security setup, consider the Wyze Duo Cam Doorbell and the Secure Entry Doorbell v2 Starter Kit:
- Wyze Duo Cam Doorbell: Offers dual camera views for people and packages, 2K video resolution, and local storage capabilities. It supports 24/7 local recording with a microSD card and hardwired power.
- Secure Entry Doorbell v2 Starter Kit: Includes a Wyze Doorbell v2 and a 128GB MicroSD card, providing 2K video resolution and local recording. It also features two-way audio and motion-activated voice deterrence.
These products will help you achieve a robust and reliable video monitoring system for your home.
