For those looking to power their Wyze Cam v3 outdoors with a compact solution, we recommend the Wyze Outdoor Power Adapter. Here are some key features:
- Weather Resistance: The adapter is IP67 rated, making it suitable for use in various weather conditions, including rain, snow, or shine.
- Compatibility: It is compatible with Wyze Cam v3, ensuring seamless integration with your existing setup.
- Cable Length: The adapter comes with a 12.5 ft (3.8 m) cable, providing flexibility in positioning your camera while keeping the power source discreetly hidden.
- Included Accessories: The package includes a weatherproof L-shaped Micro-USB adapter, wire clips, screws, and anchors for easy installation.
- Operating Temperature: It functions effectively in temperatures ranging from -22°F to 122°F (-30°C to 50°C).
This adapter is designed to provide reliable power to your Wyze Cam v3 while maintaining a neat and unobtrusive appearance.
