Compact Design Doorbells That Blend Seamlessly With Your Home Exterior
When it comes to securing your home entrance, a doorbell that combines sleek, compact design with powerful smart features is essential. Wyze offers two standout video doorbells that not only provide crystal-clear video and smart alerts but also blend effortlessly with any home exterior. Whether you prefer a wired or battery-powered option, Wyze has you covered with the
Wyze Video Doorbell v2 and the
Wyze Duo Cam Battery Doorbell.
Wyze Video Doorbell v2: Wired, Sleek, and Feature-Rich
Compact and Stylish Design
The Wyze Video Doorbell v2 is designed with a slim profile measuring just 4.3 inches by 1.7 inches by 0.9 inches (110mm x 44mm x 24mm), making it unobtrusive and perfect for blending with any home exterior. Its black polycarbonate body and resin lens give it a modern, durable look that complements various architectural styles.
Superior Video Quality
Capture every detail with 2K resolution (2048 x 1536) video powered by a CMOS Starlight Sensor and an F2.0 aperture lens. The doorbell offers a wide 135° horizontal and 103° vertical field of view, ensuring you see everything happening at your doorstep. Daytime video streams at 20 FPS, while nighttime footage is smooth at 15 FPS, enhanced by 6 infrared LEDs for clear night vision.
Smart Features for Enhanced Security
- Two-way audio with noise and echo cancellation lets you communicate with visitors from anywhere.
- Real-time motion alerts keep you informed instantly.
- Motion-activated voice deterrence warns off unwanted guests.
- Local microSD storage up to 256GB plus optional cloud storage with Wyze Security Plan.
- IP65 weather resistance ensures reliable performance in all weather conditions.
Easy Installation and Integration
Powered by 16V-24V AC wiring, the Wyze Video Doorbell v2 comes with a chime controller, wall plate, wedge mount, and all necessary installation hardware. It integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
Compact and stylish Wyze Video Doorbell v2 installed on a modern home exterior
Wyze Duo Cam Battery Doorbell: Advanced Dual Cameras with Wireless Convenience
Modern Design That Fits Any Home
The Wyze Duo Cam Doorbell features a sleek, compact design measuring 5.90 inches by 1.88 inches by 1.18 inches (150mm x 48mm x 30mm) with a lightweight plastic body and resin lens. Available in black or silver, it complements any home exterior with a contemporary look.
Dual Camera Views for Complete Coverage
This doorbell offers two cameras: a front-facing 2K camera (2048 x 1536) with a 132° horizontal and 100° vertical field of view, and a bottom-facing 1080p camera with a 121° horizontal and 60° vertical view. This dual perspective lets you monitor both visitors and packages with precision.
Wireless Power and Flexible Installation
Powered by a rechargeable 6200 mAh lithium-ion battery pack, the Duo Cam Doorbell can also be hardwired for continuous power. The USB-C charging port makes recharging simple. Its IP65 weather resistance rating ensures durability in all climates.
Intelligent Security Features
- Real-time AI detections and alerts distinguish people and packages.
- Two-way audio with a built-in speaker and microphone for clear communication.
- Motion-activated voice deterrence warns intruders with a 90 dB siren and voice alerts.
- Supports local storage up to 256GB microSD and cloud storage on AWS.
- Connects via dual-band Wi-Fi (2.4 GHz & 5 GHz) and Bluetooth 5.0.
- Compatible with Alexa, Google Assistant, and IFTTT for smart home control.
Included Accessories for Easy Setup
The package includes a Wyze Wi-Fi Chime, back plate, corner kit, USB-C charging cable, wire nuts, extension wires, screws, adhesive tape, and a removable battery pack for hassle-free installation.
Wyze Duo Cam Doorbell installed on a stylish home exterior, blending security with design
Why Choose Wyze Doorbells for Your Home?
"Wyze doorbells combine compact, modern design with advanced video technology and smart home integration, making them the perfect choice for any home exterior."
Both the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell offer exceptional video clarity, reliable weather resistance, and intelligent features that enhance your home security without compromising style. Whether you want the convenience of a wired doorbell or the flexibility of a battery-powered model, Wyze provides solutions that blend seamlessly with your home’s exterior aesthetics.
Summary of Key Specs
Feature | Wyze Video Doorbell v2 | Wyze Duo Cam Battery Doorbell |
Video Resolution | 2K (2048 x 1536) | Front: 2K (2048 x 1536), Bottom: 1080p |
Field of View | 135° horizontal, 103° vertical | Front: 132° horizontal, 100° vertical; Bottom: 121° horizontal, 60° vertical |
Power Source | Wired (16V-24V AC) | Battery (6200 mAh) or Hardwired |
Weather Resistance | IP65 | IP65 |
Two-Way Audio | Yes | Yes |
Storage | Local microSD (up to 256GB), Cloud | Local microSD (up to 256GB), Cloud |
Smart Home Integration | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT |
Dimensions | 4.3" x 1.7" x 0.9" | 5.90" x 1.88" x 1.18" |
Choose Wyze for a compact, stylish, and smart video doorbell that enhances your home security while perfectly complementing your home’s exterior design.
What are the main differences between the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell?
The Wyze Video Doorbell v2 is a wired doorbell with a slim, compact design and 2K video resolution, while the Wyze Duo Cam Battery Doorbell offers dual cameras (front-facing 2K and bottom-facing 1080p), wireless battery-powered operation, and the option to hardwire for continuous power. Both models feature IP65 weather resistance, two-way audio, local and cloud storage, and smart home integration with Alexa, Google Assistant, and IFTTT.Are Wyze doorbells compatible with smart home systems like Alexa and Google Assistant?
Yes, both the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration into your smart home ecosystem.What video quality do Wyze doorbells provide?
The Wyze Video Doorbell v2 delivers 2K resolution (2048 x 1536) video, while the Wyze Duo Cam Battery Doorbell features a front-facing 2K camera and a bottom-facing 1080p camera for comprehensive coverage and crystal-clear video quality.Can Wyze doorbells be used in all weather conditions?
Yes, both Wyze doorbells are rated IP65 for weather resistance, ensuring reliable performance in rain, snow, and other challenging weather conditions.Do Wyze doorbells support local and cloud storage?
Yes, both the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell support local storage via microSD cards up to 256GB, as well as optional cloud storage through the Wyze Security Plan.How do the Wyze doorbells enhance home security?
Wyze doorbells offer advanced security features such as real-time motion alerts, AI-powered detections (including people and packages), two-way audio with noise and echo cancellation, motion-activated voice deterrence, and a 90 dB siren (on the Duo Cam model) to help protect your home.What are the installation options for Wyze doorbells?
The Wyze Video Doorbell v2 is designed for wired installation (16V-24V AC) and comes with all necessary hardware. The Wyze Duo Cam Battery Doorbell can be installed wirelessly using its rechargeable battery or hardwired for continuous power, offering flexible installation options.What accessories are included with Wyze doorbells?
The Wyze Video Doorbell v2 includes a chime controller, wall plate, wedge mount, and installation hardware. The Wyze Duo Cam Battery Doorbell comes with a Wi-Fi chime, back plate, corner kit, USB-C charging cable, wire nuts, extension wires, screws, adhesive tape, and a removable battery pack.How compact are Wyze doorbells and will they blend with my home exterior?
Wyze doorbells are designed with a sleek, compact profile to blend seamlessly with any home exterior. The Wyze Video Doorbell v2 measures 4.3" x 1.7" x 0.9", while the Wyze Duo Cam Battery Doorbell measures 5.90" x 1.88" x 1.18". Both are available in modern finishes to complement various architectural styles.What connectivity options do Wyze doorbells offer?
The Wyze Video Doorbell v2 connects via Wi-Fi, while the Wyze Duo Cam Battery Doorbell supports dual-band Wi-Fi (2.4 GHz & 5 GHz) and Bluetooth 5.0 for reliable and flexible connectivity.
