Enhance Your Wyze Cam Setup with a 20ft USB Extension Cable for Optimal Coverage in Open Concept Family Rooms
For those looking to extend the reach of their Wyze Cam in an open concept family room, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here's why we recommend it:
  • Extended Reach: With a length of 20ft, this USB extension cable provides the flexibility to position your Wyze Cam exactly where you need it, without being limited by short cables.
  • Compatibility: It is compatible with a wide range of Wyze Cams, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Weather Resistant: The cable has an IP67 weather rating, making it suitable for both indoor and outdoor use.
  • Easy Installation: Designed for easy setup, allowing you to quickly extend your camera's reach.
Additionally, if you're considering upgrading or adding more cameras to your setup, here are some options:
  • Wyze Cam OG Telephoto: Offers a 3x telephoto lens for capturing distant details, with features like 1080p HD resolution, color night vision, and IP65 weather resistance.
  • Wyze Cam OG: Provides a wide-angle view with a built-in spotlight and enhanced two-way audio, perfect for comprehensive coverage of your family room.
  • Wyze Cam v4: Delivers crystal-clear 2.5K QHD resolution and enhanced color night vision, along with motion-activated spotlight and Wi-Fi 6 support for seamless connectivity.
These products can help you achieve optimal coverage and functionality in your open concept family room.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OG TelephotoWyze Cam OGWyze Cam v4
TypeAccessoriesCamerasCamerasCameras
Length20ftN/AN/AN/A
CompatibilityWyze Cam v2/v3/v4, Pan v2/v3, OGStandalone or with Wyze Cam OGStandalone or with Wyze Cam OG TelephotoWyze Cam v4
Weather ResistanceIP67IP65IP65IP65
ResolutionN/A1080p HD1080p HD2.5K QHD
Night VisionN/AColor Night VisionColor Night VisionEnhanced Color Night Vision
Field of ViewN/A27° (DFOV)120° (DFOV)115.8° (DFOV)
Telephoto LensN/A3xNoNo
Built-in SpotlightN/ANoYesYes
Two-Way AudioN/AYesYesImproved 2-way audio
Wi-Fi SupportN/A2.4 GHz2.4 GHzWi-Fi 6
Local StorageN/ASupports up to 256 GB microSDSupports up to 256 GB microSDSupports up to 512 GB microSD
Price$7.99$25.98 (1 Pack)$29.98 (1 Pack)$29.98 (1 Pack)
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Wyze Cam OG Telephoto compared to other models?Do you have any ongoing sales or discounts for Wyze products?
