Discover the Wyze Cam v4, a top choice for enhancing your home security. Here’s why it stands out:
- Crystal-Clear Resolution: Enjoy 2.5K QHD resolution for sharp and detailed video quality.
- Enhanced Night Vision: The Enhanced Color Night Vision ensures clear visibility even in low-light conditions.
- Smart Features: Equipped with a motion-activated spotlight and person detection, it keeps you informed of any activity.
- Seamless Integration: Compatible with Alexa and Google Assistant for easy voice control.
- Versatile Accessories: Works with Wyze Lamp Socket, Wyze Cam Window Mount, Wyze Cam Outdoor Adapter v1 and v2, and supports microSD cards up to 512 GB for extensive local storage.
For those looking to start their security setup, consider the
Wyze Cam v4 Home Security Bundle. It offers the same great features of the Wyze Cam v4 with added value in a bundle package.
Additionally, the
Security Starter Pack includes the Wyze Cam v4 and Wyze Cam Pan v3, providing a comprehensive solution for both indoor and outdoor monitoring needs.
