Best Refurbished Robot Vacuum with LIDAR & 2100 Pa Suction
Best Refurbished Robot Vacuum with LIDAR and 2100 Pa Suction
Looking for the best refurbished robot vacuum that combines advanced LIDAR navigation with powerful suction of 2100 Pa? Discover the Wyze Robot Vacuum, a smart cleaning solution designed to map your home precisely and clean efficiently with strong suction power. Alongside, explore complementary Wyze vacuum products and accessories to enhance your home cleaning experience.
Wyze Robot Vacuum: Precision Cleaning with LIDAR and 2100 Pa Suction
Advanced LIDAR Room Mapping and Path Planning
The Wyze Robot Vacuum stands out with its invisible spinning LIDAR laser sensor that builds an exact map of your home. This technology allows the vacuum to navigate intelligently, avoiding collisions and efficiently dividing rooms into sections for thorough cleaning.
"Unlike other vacuums that bump into furniture, Wyze Robot Vacuum uses precise LIDAR to clean your home methodically."
Powerful 2100 Pa Suction for Deep Cleaning
Equipped with a high-torque center brush and an edge brush, this robot vacuum delivers 2100 Pa suction power to pull up dust, dirt, and pet hair from all floor types. Whether you have hardwood floors or carpets, it adapts seamlessly.
Smart Sensors and All-Wheel Drive
With 7 sensor groups, the vacuum detects obstacles, stairs, and walls, ensuring safe and smooth operation. Its all-wheel drive can cross height gaps up to 0.8 inches (20mm), making it perfect for multi-surface homes.
Convenient Features
  • Automatically returns to its charging dock when the battery is low or cleaning is complete.
  • Resumes cleaning after recharging to finish the job.
  • Compatible with Alexa voice commands for hands-free control.
Battery Life: Up to 110 minutes in standard mode, ideal for medium to large homes. Wyze Robot Vacuum Lifestyle Wyze Robot Vacuum mapping and cleaning efficiently in a modern home
Wyze Cordless Vacuum S: Lightweight Powerhouse for Spot Cleaning
Exceptional Suction Power
Though not a robot vacuum, the Wyze Cordless Vacuum S offers an impressive 20,000 Pa suction power with two powerful motors—one in the main body and one in the brush head. This makes it perfect for quick, handheld cleaning tasks where precision and power are needed.
Ultra-Lightweight and Portable
Weighing just 2.8 pounds, it’s as light as a fluffy corgi puppy, making it easy to maneuver around furniture and tight spaces.
Long-Lasting Battery
Enjoy up to 40 minutes of fade-free cleaning with an interchangeable lithium-ion battery, ensuring you can finish your cleaning without interruptions.
Versatile Cleaning Speeds and LED Illumination
Choose from three suction levels (Eco 6,000 Pa, Medium 9,000 Pa, Turbo 20,000 Pa) to suit different surfaces. Six bright LED lights on the brush head illuminate dust and debris under furniture for thorough cleaning.
Easy Maintenance
  • 3-stage filtration system including HEPA filter removes 95% of particles as small as 0.3 microns.
  • Dust cup and filters are washable and easy to empty with one finger.
Wyze Cordless Vacuum S Lifestyle Wyze Cordless Vacuum S in action, perfect for pet hair and sofa cleaning
Essential Accessories for Your Wyze Robot Vacuum
Wyze Robot Vacuum - Replacement Parts Kit
Keep your robot vacuum running at peak performance with the Replacement Parts Kit. It includes:
  • 4 Edge brushes
  • 2 Main brushes
  • 4 HEPA filters
Regular maintenance with genuine parts ensures your vacuum maintains its powerful suction and efficient cleaning path.
Wyze Robot Vacuum - HEPA Filter
Replace your HEPA filter easily to maintain optimal allergen filtration and air quality in your home.
Why Choose Wyze Refurbished Robot Vacuum?
  • Precision LIDAR navigation ensures no corner is missed and no furniture is bumped.
  • Strong 2100 Pa suction cleans deeply on all floor types.
  • Smart sensors and all-wheel drive handle obstacles and uneven surfaces effortlessly.
  • Long battery life and automatic recharge provide uninterrupted cleaning.
  • Affordable refurbished pricing offers great value without compromising quality.
"Wyze Robot Vacuum is a top choice for anyone seeking a smart, powerful, and affordable robot vacuum with advanced navigation and suction."
Summary of Featured Products
ProductKey FeaturesPrice (Refurbished)
Wyze Robot VacuumLIDAR mapping, 2100 Pa suction, Alexa compatible, 110 min battery$99.98 (Sold Out)
Wyze Cordless Vacuum S20,000 Pa suction, 2 motors, 40 min battery, ultra-lightweight$139.99
Wyze Robot Vacuum PartsReplacement brushes and HEPA filters for maintenance$22.99 (Kit), $4.99 (Filter)
Optimize your home cleaning with the best refurbished robot vacuum featuring LIDAR and 2100 Pa suction power. The Wyze Robot Vacuum delivers intelligent, efficient, and powerful cleaning, while the Wyze Cordless Vacuum S complements your cleaning arsenal with handheld versatility and strong suction.
Product NameTypePrice (USD)Compare at Price (USD)DescriptionKey FeaturesCompatibilityColor / Additional Info
Wyze Robot VacuumConnected Home99.98314.99Room mapping. Path planning. Efficient cleaning.Room mapping, path planning, efficient cleaning-Black
Wyze Cordless Vacuum SConnected Home139.99193.99Cordless vacuum with 20,000 Pa suction power, 40-min battery, two motors20,000 Pa suction, 40-min battery, 2 motors-Steel grey with Wyze green accents
Wyze Robot Vacuum - HEPA FilterReplacement Parts4.99-Replacement HEPA vacuum filterCompatible with Wyze Robot VacuumWyze Robot Vacuum-
Wyze Robot Vacuum - Replacement Parts KitReplacement Parts22.99-Includes Edge brush4, Main brush2, HEPA filter*4Full maintenance kit for Wyze Robot VacuumWyze Robot Vacuum-
What makes the Wyze Robot Vacuum the best refurbished robot vacuum with LIDAR and 2100 Pa suction?The Wyze Robot Vacuum stands out as the best refurbished robot vacuum due to its advanced LIDAR navigation, which precisely maps your home for efficient cleaning, and its powerful 2100 Pa suction that effectively removes dust, dirt, and pet hair from all floor types. Its smart sensors, all-wheel drive, and compatibility with Alexa make it a top choice for smart, thorough, and convenient cleaning.
How does LIDAR navigation improve the cleaning performance of the Wyze Robot Vacuum?LIDAR navigation uses an invisible spinning laser sensor to create an exact map of your home. This allows the Wyze Robot Vacuum to navigate intelligently, avoid collisions, and divide rooms into sections for methodical and thorough cleaning, ensuring no area is missed.
What types of floors can the Wyze Robot Vacuum clean with its 2100 Pa suction?The Wyze Robot Vacuum is designed to clean all floor types, including hardwood, tile, and carpets. Its 2100 Pa suction power, combined with a high-torque center brush and edge brush, ensures deep cleaning on any surface.
How long does the Wyze Robot Vacuum battery last on a single charge?The Wyze Robot Vacuum offers up to 110 minutes of cleaning time in standard mode, making it ideal for medium to large homes. It automatically returns to its charging dock when the battery is low and resumes cleaning after recharging.
Is the Wyze Robot Vacuum compatible with Alexa?Yes, the Wyze Robot Vacuum is compatible with Alexa voice commands, allowing for hands-free control and easy integration into your smart home setup.
What maintenance accessories are available for the Wyze Robot Vacuum?Essential accessories for the Wyze Robot Vacuum include the Replacement Parts Kit, which contains edge brushes, main brushes, and HEPA filters, as well as individual HEPA filters. Regular replacement of these parts ensures optimal suction and cleaning performance.
What is included in the Wyze Robot Vacuum Replacement Parts Kit?The Wyze Robot Vacuum Replacement Parts Kit includes 4 edge brushes, 2 main brushes, and 4 HEPA filters, providing everything needed for regular maintenance and peak performance.
How does the Wyze Cordless Vacuum S differ from the Wyze Robot Vacuum?The Wyze Cordless Vacuum S is a lightweight, handheld vacuum designed for spot cleaning with an impressive 20,000 Pa suction power. Unlike the robot vacuum, it is manually operated, making it ideal for quick cleanups, furniture, and tight spaces.
What filtration system does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter that removes 95% of particles as small as 0.3 microns, ensuring cleaner air and effective allergen removal.
Why should I choose a refurbished Wyze Robot Vacuum?Choosing a refurbished Wyze Robot Vacuum offers advanced features like precision LIDAR navigation, strong 2100 Pa suction, smart sensors, and long battery life at an affordable price, providing excellent value without compromising on quality or performance.
What are the key features of the Wyze Cordless Vacuum S?How does the LIDAR navigation in the Wyze Robot Vacuum work?Are there any ongoing sales or discounts for the Wyze products?
