Securely Mount Your Wyze Cam v4: Best Ceiling and Wall Installation Methods
For securely mounting your Wyze Cam v4 on a ceiling or wall, we offer several convenient options. The Wyze Cam v4 comes with versatile mounting options including a stand, wall mount, ceiling mount, and a magnetic wall mount with adhesive. These options ensure that you can place your camera in the optimal position for monitoring your space effectively. The camera's compact dimensions of 2 inches x 2 inches x 2 3/8 inches and lightweight design make it easy to install without compromising on stability. Additionally, the camera's IP65 weather resistance ensures it can withstand various environmental conditions, making it suitable for both indoor and outdoor use.
What are the different mounting options available for the Wyze Cam v4?Can the Wyze Cam v4 be used outdoors, and how does its weather resistance work?What are the dimensions of the Wyze Cam v4?
