Best Bundle for Video Doorbell and Smart Lock Replacement
Upgrading your home security with a smart lock and video doorbell bundle is the smartest way to enhance convenience, safety, and control. For those looking to replace their existing deadbolt and add a video doorbell, the
Wyze Lock Bolt combined with Wyze’s video doorbell solutions offers a seamless, reliable, and feature-rich smart home experience.
Wyze Lock Bolt: The Ultimate Smart Lock Replacement
Key Features and Benefits
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger, eliminating the need for keys.
- Backlit Keypad with Anti-Peep Technology: Enter your code securely even in the dark, with protection against prying eyes.
- Auto-Lock Function: Never worry about forgetting to lock your door again; the lock auto-secures itself.
- Lock and Unlock History: Monitor who enters and exits your home via the Wyze app.
- Built-in Alarm for Jam Detection: Alerts you immediately if the lock is tampered with or jammed.
- Emergency One-Time Codes: Provide temporary access to guests or service personnel without sharing permanent codes.
- Easy Installation: Replaces your existing deadbolt in minutes without professional help.
Technical Specifications
- Communication: Bluetooth 5.0 with a 16 ft range.
- Power Source: 4x AA batteries included, lasting 10-12 months.
- Weather Resistance: Rated IPX5, suitable for outdoor use.
- Operating Temperature: Keypad works from -13°F to 122°F.
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
Style Options
The Wyze Lock Bolt is perfect for anyone tired of fumbling with keys and wanting a secure, smart, and stylish upgrade to their home entry.
Secure your front door with Wyze Lock Bolt
Wyze Lock: Add Smart Control to Your Existing Deadbolt
If you prefer to keep your current deadbolt but want to add smart features, the
Wyze Lock is an excellent choice.
Highlights
- Auto-Unlock: The lock senses your phone and unlocks automatically as you approach.
- Remote Access: Control your lock from anywhere using the Wyze app.
- Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
- Virtual Keys: Send temporary or permanent virtual keys to family, friends, or service providers.
- Quick Installation: Installs in under 15 minutes without replacing your deadbolt.
Technical Details
- Communication Methods: Bluetooth, Zigbee, and WiFi for versatile connectivity.
- Battery Life: 4x AA batteries included, lasting 5-6 months.
- Range: Up to 50 ft to gateway or router, 16 ft Bluetooth to phone.
- Weather Resistance: Indoor use with IPX5 rating.
- Compatibility: Works with most single cylinder deadbolts.
Available Colors
The Wyze Lock is ideal for those who want to keep their existing hardware but gain smart lock convenience and security.
Essential Replacement Parts for Wyze Lock Bolt
To maintain or upgrade your Wyze Lock Bolt, consider these replacement parts:
- Wyze Lock Bolt Screws: Affordable set of screws compatible with the Wyze Lock Bolt for secure installation.
- Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover to protect the battery compartment.
- Wyze Lock Bolt Interior Assembly Metal Plate: Metal plate to anchor the interior assembly firmly to your door.
- Wyze Lock Replacement Part Kit: Comprehensive kit including adapters and parts to keep your lock functioning smoothly.
These parts ensure your smart lock remains reliable and easy to maintain over time.
Why Choose a Bundle with Wyze Lock Bolt and Video Doorbell?
Pairing the Wyze Lock Bolt with a Wyze video doorbell creates a comprehensive home security system that lets you:
- See and speak to visitors remotely.
- Control door access with fingerprint, keypad, or app.
- Receive real-time alerts and history logs.
- Integrate with other Wyze smart home devices for automation.
This combination offers peace of mind, convenience, and modern security technology all in one package.
Control your smart lock effortlessly via app
Conclusion
For the best bundle to replace your video doorbell and smart lock, the
Wyze Lock Bolt stands out as a top choice for deadbolt replacement with advanced fingerprint and keypad features. Alternatively, the
Wyze Lock offers smart control without replacing your existing deadbolt. Both integrate seamlessly with Wyze’s video doorbells and smart home ecosystem, providing a secure, convenient, and modern home entry solution.
Upgrade your home security today with Wyze’s smart lock and video doorbell bundle for ultimate control and peace of mind.
What is the best bundle for replacing a video doorbell and smart lock?
The best bundle for replacing your video doorbell and smart lock is the Wyze Lock Bolt paired with a Wyze video doorbell. This combination offers advanced security features, seamless integration, and convenient control through the Wyze app.What are the key features of the Wyze Lock Bolt smart lock?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, lock and unlock history tracking, built-in alarm for jam detection, emergency one-time codes, and easy installation that replaces your existing deadbolt in minutes.How do I install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy DIY installation. It replaces your existing deadbolt and fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”. No professional help is required, and installation can be completed in minutes.What are the technical specifications of the Wyze Lock Bolt?
The Wyze Lock Bolt uses Bluetooth 5.0 with a 16 ft range, is powered by 4 AA batteries (lasting 10-12 months), is weather resistant with an IPX5 rating, and operates in temperatures from -13°F to 122°F.Can I keep my existing deadbolt and still use a Wyze smart lock?
Yes, the Wyze Lock allows you to add smart features to your existing deadbolt. It offers auto-unlock, remote access, voice control with Alexa and Google Assistant, and virtual keys, all without replacing your current hardware.What connectivity options does the Wyze Lock offer?
The Wyze Lock supports Bluetooth, Zigbee, and WiFi connectivity, allowing for versatile control and remote access through the Wyze app.Are there replacement parts available for the Wyze Lock Bolt?
Yes, essential replacement parts for the Wyze Lock Bolt include screws, an interior assembly battery cover, an interior assembly metal plate, and a comprehensive replacement part kit to keep your lock functioning smoothly.What are the benefits of bundling a Wyze Lock Bolt with a Wyze video doorbell?
Bundling a Wyze Lock Bolt with a Wyze video doorbell provides comprehensive home security, allowing you to see and speak to visitors remotely, control door access via fingerprint, keypad, or app, receive real-time alerts, and integrate with other Wyze smart home devices.What color options are available for the Wyze Lock Bolt and Wyze Lock?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel, while the Wyze Lock comes in Silver and White.How long do the batteries last in Wyze smart locks?
The Wyze Lock Bolt's 4 AA batteries last approximately 10-12 months, while the Wyze Lock's batteries last about 5-6 months, depending on usage.
