For those looking to mount a Wyze camera in a sun-facing window, the Wyze Window Mount is an excellent choice. Here’s why we recommend it:
- Compatibility: It works seamlessly with Wyze Cam v3, v3 Pro, v4, Cam OG, and Cam OG Telephoto, ensuring you have a clear view without glare or reflection.
- Design: Specifically designed to mount on glass surfaces, it reduces glare, providing a clear and unobstructed view.
- Versatility: Ideal for enhancing exterior security by allowing you to attach your camera directly to a window.
Additionally, if you're interested in a plug-and-play solution for outdoor lighting, the Wyze Cam Floodlight Plug-In Mount is a great option. It simplifies installation without the need for a junction box and is compatible with various Wyze Cam Floodlight models.
For bird enthusiasts, the Wyze Bird Feeder offers a unique way to use your Wyze camera for birdwatching, with easy installation and live video streaming capabilities.
