Enhance Your Wyze Cam Setup with a 20ft USB Extension Cable and Reliable Power Solutions
For those looking to enhance their Wyze Cam setup with a reliable power solution and extended reach, we recommend the following products:
  • Wyze Cam USB Extension Cable - 20ft: This accessory is perfect for extending the reach of your Wyze Cam, providing a 20ft cable length that works seamlessly with various Wyze Cam models, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and Wyze Cam OG series. It is easy to install and features an IP67 weather rating, ensuring durability in various conditions.
  • Wyze Cordless Vacuum - Battery Pack: While this product is specifically designed for the Wyze Cordless Vacuum, it highlights our range of power solutions. If you're looking for backup power options, this battery pack offers extra juice for your Wyze Cordless Vacuum, ensuring uninterrupted performance.
These products are designed to enhance your Wyze Cam experience by providing extended reach and reliable power solutions.
```markdown
FeatureWyze Cam USB Extension Cable - 20ftWyze Cordless Vacuum - Battery Pack
Product TypeAccessoriesAccessories
Compatible DevicesWyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG seriesWyze Cordless Vacuum
Cable Length20ftN/A
Weather RatingIP67N/A
Power Output5V 2AN/A
Price$7.99$29.99
Stock AvailabilityAvailableAvailable
Additional NotesCharge only, USB Type A Male to FemaleNot compatible with Wyze Cordless Vacuum S
``` If you would like more help, you can chat with an agent via our Wyze Support chat.
Can you tell me more about the installation process for the Wyze Cam USB Extension Cable?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?Do you have any ongoing sales or discounts for the Wyze Cam USB Extension Cable?
