Affordable Smart Thermostats with Energy Usage Tracking
Looking for an affordable smart thermostat that not only controls your home's temperature but also helps you track and save energy? Discover the Wyze Thermostat lineup, designed to simplify smart heating and cooling while giving you powerful energy insights. Whether you want to control your home's climate remotely, save on energy bills, or keep your pets comfortable, these smart thermostats offer excellent features at budget-friendly prices.
Wyze Thermostat: Smart Heating & Cooling Simplified
The Wyze Thermostat is a standout choice for anyone seeking an affordable, easy-to-use smart thermostat with energy usage tracking capabilities.
Key Features:
  • Remote Temperature Control: Adjust your thermostat from anywhere in the world using the Wyze app. Whether you're at work or on vacation, you can ensure your home is always at the perfect temperature.
  • Energy Savings: The thermostat learns your schedule and helps reduce wasted energy by turning off heating or cooling when you're away.
  • Voice Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for hands-free temperature adjustments.
  • Wyze Room Sensor Support: Eliminate hot and cold spots by placing sensors in different rooms. The thermostat balances your home's climate based on where motion is detected, saving energy by focusing on occupied rooms.
  • Simple Scheduling: Create daily schedules for weekdays and weekends to automate your home's heating and cooling.
  • Energy Usage Insights: Receive personalized energy-saving tips based on your usage history through the Wyze app, helping you reduce your energy bills without sacrificing comfort.
  • Easy Installation: A 20-minute DIY installation guided step-by-step in the app makes setup hassle-free.
Specifications:
  • Wireless setup with up to 6 room sensors supported
  • Always-on display with easy-to-read interface
  • Compatible with Android 9.0+ and iOS 15.0+
  • Power source: 24VAC through C terminal with included C-wire adapter
  • Operating temperature range: 32°F to 130°F (0°C to 55°C)
"Arrive home to the perfect temperature and save energy effortlessly."
Refurbished Option for Even More Savings
For budget-conscious buyers, the (Refurbished) Wyze Thermostat offers the same smart features at a fraction of the price. Fully tested and guaranteed to work like new, this option is perfect if you want to enjoy smart climate control without breaking the bank.
Cozy home with smart thermostat control Alt text: Cozy living room with smart thermostat control for energy savings
Why Choose Wyze Thermostat for Energy Usage Tracking?
Wyze Thermostat stands out because it combines affordability with smart features that help you monitor and reduce your energy consumption. The integration with Wyze Room Sensors and the app’s energy-saving recommendations make it easy to optimize your home's heating and cooling without constant manual adjustments.
Additional Smart Home Devices to Complement Your Thermostat
While the Wyze Thermostat is the perfect solution for smart temperature control and energy tracking, consider enhancing your connected home with these complementary Wyze products:
Wyze Scale S (Health & Lifestyle)
Though not a thermostat, the Wyze Scale S is an affordable smart device that tracks your health metrics with precision. It features:
  • Ultra-precise measurements including muscle mass, body fat, and bone mass
  • Auto-recognition for up to 8 users
  • Syncs with popular fitness apps
  • Baby and pet mode for tracking loved ones’ weight
  • Up to 18 months battery life
Lifestyle image of Wyze Scale S in home setting Alt text: Modern bathroom with Wyze Scale S smart scale on floor
Wyze Wi-Fi 6E Mesh Router Pro (Connected Home)
Ensure your smart thermostat and other devices stay connected with the Wyze Wi-Fi 6E Mesh Router Pro:
  • Internet speeds up to 2.5 Gbps with Wi-Fi 6E technology
  • Coverage up to 2000 sq. ft. per router, supporting 75+ devices
  • Simple setup and parental controls
  • Supports 2.4 GHz, 5 GHz, and 6 GHz bands for seamless connectivity
Conclusion
For an affordable smart thermostat with robust energy usage tracking, the Wyze Thermostat and its refurbished version offer unbeatable value. With remote control, voice assistant compatibility, room sensors, and energy-saving insights, you can enjoy comfort and savings all year round. Pair it with other Wyze smart home devices for a fully integrated, efficient home environment.
FeatureWyze Thermostat (Refurbished)Wyze Thermostat (New)
Price$29.98$79.98
ConditionRefurbished, like new, fully testedNew
Return PolicyFinal sale, no returns (Wyze decision)30-day hassle-free returns
Smart Heating & CoolingYesYes
Remote Control via AppYesYes
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google Assistant
Wyze Room Sensor SupportYes, supports up to 6 sensorsYes, supports up to 6 sensors
Motion-Sensing Comfort ModeYesYes
Always-on DisplayYesYes
Wireless SetupYesYes
SchedulingSimple daily schedulingSimple daily scheduling
Energy-saving TipsYes, based on usage historyYes, based on usage history
Installation20-minute DIY with app guidance20-minute DIY with app guidance
WarrantyNot specifiedNot specified
AvailabilitySold outSold out
What features make the Wyze Thermostat an affordable smart thermostat with energy usage tracking?The Wyze Thermostat offers remote temperature control via the Wyze app, energy usage tracking with personalized tips, voice assistant compatibility (Alexa and Google Assistant), support for Wyze Room Sensors to eliminate hot and cold spots, simple scheduling, and easy DIY installation—all at a budget-friendly price.
How does the Wyze Thermostat help save energy and reduce utility bills?The Wyze Thermostat learns your schedule to automatically adjust heating and cooling when you're away, provides energy usage insights through the Wyze app, and offers personalized energy-saving tips. Room sensors help focus climate control on occupied rooms, further reducing wasted energy.
Can I control the Wyze Thermostat remotely?Yes, you can control the Wyze Thermostat from anywhere in the world using the Wyze app on your smartphone, allowing you to adjust your home's temperature even when you're not at home.
Is the Wyze Thermostat compatible with voice assistants?Yes, the Wyze Thermostat works seamlessly with Amazon Alexa and Google Assistant, enabling hands-free temperature adjustments using voice commands.
What is the benefit of using Wyze Room Sensors with the Wyze Thermostat?Wyze Room Sensors help eliminate hot and cold spots by detecting motion and adjusting the temperature based on occupied rooms. This targeted climate control saves energy and ensures comfort throughout your home.
How easy is it to install the Wyze Thermostat?The Wyze Thermostat features a 20-minute DIY installation process, guided step-by-step through the Wyze app, making setup simple and hassle-free for most users.
What are the technical requirements for the Wyze Thermostat?The Wyze Thermostat requires a 24VAC power source through a C terminal (with an included C-wire adapter), supports up to 6 room sensors, and is compatible with Android 9.0+ and iOS 15.0+ devices. It operates in temperatures ranging from 32°F to 130°F (0°C to 55°C).
Is there a refurbished Wyze Thermostat option available?Yes, the (Refurbished) Wyze Thermostat offers the same smart features as the new model at a lower price. It is fully tested and guaranteed to work like new, making it a great choice for budget-conscious buyers.
How does the Wyze Thermostat provide energy usage insights?The Wyze Thermostat tracks your energy usage and delivers personalized energy-saving tips through the Wyze app, helping you monitor and reduce your energy consumption without sacrificing comfort.
What other Wyze smart home devices complement the Wyze Thermostat?Complementary Wyze devices include the Wyze Scale S, which tracks health metrics, and the Wyze Wi-Fi 6E Mesh Router Pro, which ensures reliable connectivity for all your smart home devices, including the thermostat.
What are the key features of the Wyze Thermostat?How does the Wyze Thermostat help in reducing energy consumption?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Thermostat?
