Affordable Refurbished Battery Security Cameras with PIR & Wide View
Affordable Refurbished Battery Powered Indoor Outdoor Security Cameras with PIR Motion Detection and Wide View
Looking for an affordable, reliable security camera that works both indoors and outdoors? Whether you want to monitor your home, yard, or business, these Wyze security cameras offer excellent value with advanced features like PIR motion detection, wide-angle views, and battery-powered convenience. Explore the best options that combine affordability, smart technology, and easy installation.
Wyze Cam v4 – Versatile Indoor/Outdoor Security with Wide View
Wyze Cam v4 is a top choice for those seeking a budget-friendly, battery-powered security camera with a wide field of view and PIR motion detection. This camera delivers crystal-clear 2.5K QHD video with enhanced color night vision, ensuring you never miss a detail day or night.
Key Features:
  • Wide 115.8° diagonal field of view covers more area with fewer blind spots.
  • PIR motion sensor for accurate motion detection, reducing false alerts.
  • 2.5K QHD video resolution with color night vision for sharp, vivid footage.
  • Weather-resistant IP65 rating makes it perfect for outdoor use.
  • Battery powered with Wi-Fi 6 support for fast, reliable connectivity.
  • Multiple mounting options including wall, ceiling, and magnetic mounts.
  • Two-way audio and built-in siren for real-time communication and deterrence.
  • Supports local microSD storage up to 512GB for continuous recording.
Wyze Cam v4 is ideal for users who want a powerful, all-around security camera that works seamlessly indoors and outdoors without the hassle of wiring. Wyze Cam v4 Outdoor Lifestyle
Wyze Bulb Cam – 2-in-1 Security Camera and Smart LED Light Bulb
Transform any light fixture into a smart security camera with the Wyze Bulb Cam. This innovative device combines a bright, dimmable 800-lumen LED bulb with a 160° wide-angle camera, perfect for indoor or outdoor use.
Highlights:
  • Wide 160° field of view captures a broad area for better coverage.
  • PIR motion detection triggers instant alerts and activates the light.
  • 2K HD video with color night vision ensures clear images day and night.
  • Easy installation fits most standard light sockets—no wiring needed.
  • Supports local microSD storage with no subscription required.
  • Two-way audio and built-in siren for communication and security.
  • Dimmable smart LED bulb with accessory bulbs for extended lighting control.
  • Works with Alexa, Google Assistant, and IFTTT for smart home integration.
This camera is perfect for renters or anyone wanting a discreet, affordable security solution that doubles as a smart light. Wyze Bulb Cam Lifestyle
Wyze Cam Pan v3 – 360° Pan and 180° Tilt for Full Coverage
For those who want maximum coverage with a single camera, the Wyze Cam Pan v3 offers a 360° horizontal pan and 180° vertical tilt, combined with PIR motion detection and weather resistance.
Features:
  • 360° horizontal and 180° vertical movement to cover every angle.
  • 120° field of view with 1080p HD video resolution.
  • PIR motion sensor for precise motion alerts.
  • IP65 weather resistance for reliable outdoor use.
  • Two-way audio with noise and echo cancellation for clear communication.
  • Built-in siren and push notifications to deter intruders.
  • Requires Wyze Outdoor Power Adapter for outdoor battery operation.
This camera is perfect for monitoring large areas like backyards or garages with flexible viewing angles. Wyze Cam Pan v3 in Snowy Outdoor Setting
Why Choose Wyze Refurbished Security Cameras?
Affordable, reliable, and packed with features, Wyze refurbished cameras offer excellent value for your home security needs. With PIR motion detection, wide-angle lenses, and easy installation, these cameras provide peace of mind without breaking the bank.
  • Battery powered options reduce wiring hassles and allow flexible placement.
  • Wide field of view ensures fewer blind spots and better coverage.
  • Smart motion detection with AI and PIR sensors minimize false alarms.
  • Weatherproof designs suitable for indoor and outdoor environments.
  • Local storage support means no mandatory subscription fees.
  • Smart home compatibility with Alexa, Google Assistant, and IFTTT.
Summary of Recommended Models
ModelVideo ResolutionField of ViewPIR Motion DetectionBattery PoweredIndoor/OutdoorPrice Range
Wyze Cam v42.5K QHD115.8°YesYesYes$35.98+
Wyze Bulb Cam2K HD160°YesPowered by light socketYes$49.98
Wyze Cam Pan v31080p HD120° + Pan/TiltYesRequires adapterYes$39.98+
Secure your home affordably with these top Wyze refurbished security cameras that combine battery power, PIR motion detection, and wide views for comprehensive indoor and outdoor protection.
### Product Tags Recap
FeatureWyze Cam v4Wyze Bulb CamWyze Cam Pan v3Wyze Cam OG
TypeWired Security CameraOutdoor Security Camera + Smart LED BulbIndoor/Outdoor Pan & Tilt CameraIndoor/Outdoor Security Camera
Video Resolution2.5K QHD (2560x1440)2K HD1080p (1920x1080)1080p (1920x1080)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)160° Wide360° horizontal, 180° vertical (120° FOV)120°
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)Color Night Vision4 IR LEDs (850 nm)4 IR LEDs (850 nm)
Audio99 dB waterproof speaker, 2-way talk, noise & echo cancellation2-way audioBuilt-in speaker & mic, 2-way audio, noise & echo cancellationBuilt-in speaker & mic, noise & echo cancellation
SirenBuilt-in sirenBuilt-in siren + flashing lightsNo90 dB user-activated siren
SpotlightMotion-activated spotlight (72 lumens)Integrated smart LED bulb (dimmable 800 lumens)NoBuilt-in spotlight (40 lumens)
Motion DetectionYes, with detection zonesYes, with detection zonesYes, with detection zonesYes, with custom detection zones
Smoke & CO AlertsYesNot specifiedNot specifiedYes
Local StoragemicroSD card up to 512 GB (required)microSD card up to 256 GBmicroSD card up to 256 GBmicroSD card up to 256 GB
Cloud StorageSubscription availableSubscription availableSubscription availableSubscription available
Connectivity2.4 GHz Wi-Fi + Wi-Fi 6, Bluetooth 5.22.4 GHz Wi-Fi2.4 GHz Wi-Fi (no 5 GHz)2.4 GHz Wi-Fi
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Weather ResistanceIP65 (Indoor/Outdoor with outdoor power adapter sold separately)IP65 (Outdoor)IP65 (Indoor/Outdoor with outdoor power adapter sold separately)IP65 (Indoor/Outdoor)
Power SourceWired (USB power adapter included)Powered by light fixtureWired (USB power adapter included)Wired (USB power adapter included)
Dimensions2in x 2in x 2 3/8in (approx. 50.8 x 50.8 x 60.3 mm)Bulb size fits most fixtures124mm (H) x 60mm (W) x 63mm (D)1.89 in x 1.89 in x 1.89 in (48mm cube)
Weight0.49 lb (222 g)Not specified11.29 oz (320 g)4.1 oz (116 g)
Special FeaturesAuto-zoom with AI, Wide Dynamic Range (WDR), Bluetooth setup, Motion-activated spotlight and sirenDimmable LED bulb, accessory bulbs sync, motion-activated lights360° pan, 180° tilt, 8x digital zoom, noise & echo cancellationFaster live streaming, 3x faster notifications, upgraded 2-way audio
Price (Single Pack)$35.98$49.98$39.98$29.98
What are the benefits of choosing Wyze refurbished security cameras?Wyze refurbished security cameras offer affordability, reliability, and advanced features such as PIR motion detection, wide-angle lenses, and easy installation. They are suitable for both indoor and outdoor use, support local storage to avoid subscription fees, and are compatible with smart home systems like Alexa, Google Assistant, and IFTTT.
Are Wyze security cameras suitable for both indoor and outdoor use?Yes, Wyze security cameras like the Cam v4, Bulb Cam, and Cam Pan v3 are designed for both indoor and outdoor environments. They feature weather-resistant designs with IP65 ratings, making them reliable for various locations around your home or business.
Do Wyze refurbished cameras have PIR motion detection?Yes, all featured Wyze refurbished cameras, including the Cam v4, Bulb Cam, and Cam Pan v3, are equipped with PIR (Passive Infrared) motion sensors. This technology provides accurate motion detection and reduces false alerts.
What is the field of view for Wyze security cameras?Wyze security cameras offer wide fields of view: the Wyze Cam v4 has a 115.8° diagonal field of view, the Wyze Bulb Cam offers a 160° wide-angle view, and the Wyze Cam Pan v3 provides a 120° field of view with 360° pan and 180° tilt for full coverage.
Are Wyze security cameras battery powered?The Wyze Cam v4 is battery powered, offering flexible placement without wiring. The Wyze Bulb Cam is powered by the light socket it is installed in, and the Wyze Cam Pan v3 requires a Wyze Outdoor Power Adapter for outdoor battery operation.
Do Wyze cameras support local storage?Yes, Wyze cameras support local microSD card storage, allowing for continuous recording and playback without the need for a subscription. The Wyze Cam v4 supports up to 512GB microSD cards.
Can Wyze security cameras be integrated with smart home systems?Yes, Wyze security cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, enabling voice control and automation.
What video resolution do Wyze refurbished cameras offer?Wyze Cam v4 provides 2.5K QHD video resolution, Wyze Bulb Cam offers 2K HD video, and Wyze Cam Pan v3 delivers 1080p HD video, all with color night vision for clear footage day and night.
How easy is it to install Wyze security cameras?Wyze security cameras are designed for easy installation. The Wyze Cam v4 offers multiple mounting options, including wall, ceiling, and magnetic mounts. The Wyze Bulb Cam installs directly into standard light sockets, and the Cam Pan v3 can be mounted with an adapter for outdoor use.
Do Wyze cameras have two-way audio and built-in sirens?Yes, all featured Wyze cameras include two-way audio for real-time communication and built-in sirens to help deter intruders and enhance security.
What are the key features of the Wyze Cam v4?How does the PIR motion detection work in the Wyze security cameras?Do you have any deals, ongoing sales, discounts, or promotions?
