If you're looking to extend the reach of your Wyze Cam and hide wiring effectively, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here are some reasons why this product is ideal for your needs:
- Extended Reach: With a length of 20 feet, this USB extension cable allows you to position your Wyze Cam further from the power source, providing greater flexibility in camera placement.
- Compatibility: This cable is compatible with a wide range of Wyze Cam models, including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2, v3, and the Wyze Cam OG series.
- Weather Resistance: The cable features an IP67 weather rating, making it suitable for both indoor and outdoor use, ensuring durability in various weather conditions.
- Easy Installation: Designed for ease of use, this cable can be quickly set up to extend your camera's reach without hassle.
- Affordable: Priced at just $7.99, it offers a cost-effective solution to enhance your camera setup.
This extension cable is perfect for those looking to improve their camera setup by hiding wires and achieving a cleaner look.
