For those looking to protect their Wyze camera cables from UV damage while ensuring reliable outdoor performance, we recommend the Wyze Outdoor Power Adapter. Here’s why it’s a great choice:
- Weather Resistance: The Wyze Outdoor Power Adapter is IP67 weather-resistant, making it suitable for use in various weather conditions, including rain, snow, and shine.
- Compatibility: It works with a range of Wyze cameras, including the Wyze Cam v3, v3 Pro, v4, OG series, Pan v3, and Battery Cam Pro, when paired with the appropriate adapters.
- Long Cable for Flexibility: The adapter comes with a 12.5 ft cable, providing flexibility in installation and ensuring that your camera can be placed in the optimal position.
- UV Protection: While the adapter itself is designed to withstand outdoor conditions, it is also important to ensure that the cables are properly managed and protected from direct sunlight to prevent UV damage.
Additionally, if you are using the Wyze Cam Pan v3, consider pairing it with the L-Shaped Micro USB Adapter for enhanced compatibility and protection.
