Enhance Security with Wyze Window Mount: Optimal Infrared Performance Behind Glass
For those looking to enhance their security setup with a Wyze Cam while minimizing glare and reflections, the Wyze Window Mount is an excellent choice. This accessory allows you to mount your Wyze Cam v3, v3 Pro, v4, or Wyze Cam OG series directly onto a glass surface, ensuring a clear view without the interference of glare or reflection. This is particularly beneficial for maintaining optimal infrared performance when your camera is positioned behind glass.
Can the Wyze Window Mount be used with any other camera models besides the ones mentioned?What are the benefits of using the Wyze Window Mount for security purposes?Is the Wyze Window Mount easy to install on glass surfaces?
