Discover Durable Wyze Window Mounts for Frequent Camera Repositioning
For those looking for a robust window mount that can handle frequent repositioning of a camera, we recommend the Wyze Window Mount and the Wyze Universal Mount (Long).
  • Wyze Window Mount:
  • Specifically designed for Wyze Cam v3, v3 Pro, v4, and the Wyze Cam OG series.
  • Allows you to mount your camera on a glass surface, providing a clear view free of glare or reflection.
  • Available in Style v2, which is compatible with a wider range of Wyze cameras.
  • Wyze Universal Mount (Long):
  • Features a durable construction with a longer neck for versatile mounting applications, such as on ceilings or patios.
  • Compatible with Wyze Cameras that use a standard 1/4”-20 mount, including Wyze Cam v1/v2/v3, Wyze Cam v3 Pro, and Wyze Cam Pan series.
  • Adjustable to achieve the perfect angle and coverage, making it suitable for frequent repositioning.
These options provide flexibility and durability for mounting your Wyze cameras securely and conveniently.
FeatureWyze Window MountWyze Universal Mount (Long)
CompatibilityWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cam v1/v2/v3, Wyze Cam v3 Pro, Wyze Cam Pan v1/v2/v3, Wyze Cam Outdoor v1/v2, Wyze Battery Cam Pro
Mounting SurfaceGlass surfacesCeilings, patios, and other versatile locations
AdjustabilityNot specifiedAdjustable angle for desired viewing position
MaterialNot specifiedHeavy-duty metal
Price$4.99$9.99
Stock AvailabilityAvailableAvailable
Special FeaturesReduces glare, clear view free of reflectionLonger neck for versatile mounting applications
InstallationEasy to mount on glassEasy installation with included hardware
Outdoor UseNot specifiedSuitable for outdoor use, recommended to protect from direct exposure to extreme weather
Compatibility NoteOnly for Wyze Cam v3/Pro, and Wyze Cam OG SeriesNot compatible with Wyze Cam OG or OG Telephoto
Can you tell me more about the compatibility of the Wyze Window Mount with different Wyze camera models?What are the specific features of the Wyze Universal Mount (Long)?How does the Wyze Window Mount ensure a clear view without glare or reflection?
