For those looking to extend the reach of their Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here’s why it stands out:
- Extended Reach: With a length of 20 feet, this cable allows you to position your Wyze Cam exactly where you need it, even behind thick curtains or in hard-to-reach areas.
- Compatibility: It is designed to work seamlessly with a variety of Wyze Cam models, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistant: The cable has an IP67 weather rating, making it suitable for both indoor and outdoor use.
- Easy Installation: The USB Type A Male to Female connector ensures a straightforward setup process.
- Affordable: Priced at just $7.99, it offers a cost-effective solution for extending your camera's reach.
This extension cable is perfect for enhancing the flexibility and placement options of your Wyze Cam setup.
