For those looking to extend the reach of their Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is an excellent choice. Here’s why it stands out:
- Extended Reach: Say goodbye to short cables with this 20ft extension, perfect for placing your Wyze Cam above a garage door opener or in other hard-to-reach areas.
- Compatibility: This cable is designed to work seamlessly with a variety of Wyze Cam models, including Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Weather Resistant: With an IP67 weather rating, this cable is built to withstand various weather conditions, making it suitable for both indoor and outdoor use.
- Easy Installation: The cable is easy to install, ensuring a hassle-free setup for your camera.
Additionally, if you're looking to power your Wyze Cam without a plug, consider the Wyze Lamp Socket. It allows you to make your exterior lighting smart and conveniently powers Wyze Cam v3 and v4.
